| [ Total Views: 1337 | Total Replies: 6 | Thread Id: 108295 ] |
Baccaruda
Threads: 4
| posted on February 4th, 2015 at 02:20 PM |
Cracked Type 3 rear engine support / mount - fix or replace?
Hi guys.
I have a 1966 Type 3 Fastback that I have bought recently as a rolling shell. It comes with the engine but it's not installed.
Unfortunately the rear engine mount / support (nearest the back of the car) has a big crack in it. It looks like someone forgot to detatch the rear
mount and tried to take the engine out, placing all the weight of the engine in that area.
I'd like to deal with it - what would you suggest? Welding it up (which will probably look naff and may not be all that effective) or replacing it
(in which case I'll have to find a part).
Any ideas how easy or hard it would be to do this and any ideas where I might find this part? I'm based in Melbourne.
By the way, can anyone tell me to correct name for this cracked part? Is it an engine mount or engine support or known as something else?
Pic of the issue below. Thanks in advance for your help team!
| Error |
Baccaruda
Threads: 4
| posted on February 6th, 2015 at 10:00 AM |
Am I better off asking this question through the Tech Talk section of the forum guys? (Sorry, bit of a Noob)
nsuwift
Threads: 27
| posted on February 6th, 2015 at 06:06 PM |
Had this problem on my notch and think from memory just welded it. Don't know what is the best option, but can say my one has not cracked again.
eXraycer
Threads: 27
| posted on February 9th, 2015 at 09:00 PM |
Same here, mine was cracked too. Common problem. I welded mine but have also gone the whole hog and done Kafer bars so I don't think it will crack
again. I think once the gearbox mounts and the subframe rubbers start to compress it loads up the tail mount of the engine and they crack after a long
time on the road.
Baccaruda
Threads: 4
| posted on February 12th, 2015 at 06:16 AM |
Thanks for the responses guys!
vw54
| posted on February 12th, 2015 at 06:50 AM |
Would be best to drill off and weld up or re make a new one it will only crack again
from memory they are only spot welded to the rear lip
Euro_67
Threads: 75
| posted on February 12th, 2015 at 09:23 AM |
I welded min in situ. It worked fine afterward.
