[ Total Views: 697 | Total Replies: 4 | Thread Id: 108462 ]
Author: Subject:  Starter switch and more
Memberdoublecabg
Threads: 10
question.gif posted on February 26th, 2015 at 08:05 PM
Hi, a bit unsure of where to start on this.
72 double cab with later type 4 engine / alternator.
Started fine and turned round on drive. 10 minutes later when to start up again- dead. no dash lights. I didnt touch or disturb anything in between aside from getting in and out of the car.
Wiggled the key in ignition a bit, got the battery & oil lights on, on turn of switch- nothing- no click.
With key off/out, no side lights or other ancilliaries and oddly, tried the hazard lights & nothing aside from whiny relay noise.
Sounds like a short somewhere, or the starter switch died and shorting out somehow? im a bit clueless on the electrics from - thats probably obvious........
Memberpsimitar
Threads: 148
posted on February 26th, 2015 at 10:01 PM
Do you happen to have a multimeter or can you rig up a test light? Kinda hard to fault find without either of these.
Memberdoublecabg
Threads: 10
posted on February 27th, 2015 at 06:46 AM
Yeah I do.
ive checked physical connection to coil (which is what I hoped).
Memberdoublecabg
Threads: 10
posted on February 27th, 2015 at 05:39 PM
fixed
Nothing more than the battery earth. wire brush and all ok. odd, as its the first thing i checked and looked very clean as i remember.
phew
Memberpsimitar
Threads: 148
posted on February 27th, 2015 at 09:14 PM
phew
Glad it ended up being a simple fix :)
