[ Total Views: 1387 | Total Replies: 4 | Thread Id: 108471 ]
Author: Subject:  Fitting clutch cable
Memberthepie
Threads: 22
posted on February 28th, 2015 at 09:12 AM
Hi all , just removed pedal cluster to paint floor pan and having a nightmare trying to get it back to together , is there a easy way to get to keep clutch cable on ? It keeps falling off , also should there be a wing nut on other end?
Cheers Dave
MemberRestoKäfer
Threads: 14
posted on February 28th, 2015 at 10:04 AM
drill a little hole in the hook and use a split pin ,
posted on February 28th, 2015 at 10:07 AM
You keep the cable on the pedal hook by not allowing the pedal to fall rearward, keeping it upright or fwd only it will stay on the hook.
Yes, a wing nut is usually fitted, although factory fittment was a pair of jamb nuts, 14 and 11mm spanner hex
MemberOld Dubber
Threads: 25
Mood: great!
posted on February 28th, 2015 at 07:43 PM
My trick is to use a thick rubber band to keep the cable on the pedal hook. The pedal can flop around while you get the nuts/wingnut on down the back.
Grahame
visit my club site at www.vwdcqinc.org.au
MemberRestoKäfer
Threads: 14
posted on March 10th, 2015 at 04:07 PM
How did you go,
[ Queries: 40 ] [ PHP: 12.7% - SQL: 87.3% ]
