[ Total Views: 875 | Total Replies: 3 | Thread Id: 108826 ]
Author: Subject:  stroker and brakes
Memberwaltermitty
Mood: Hungry for mor
posted on April 16th, 2015 at 09:51 AM
stroker and brakes
I am in the process of collecting bits for a stroker build ( to me this is perhaps the most enjoyable part of a project ).
I am going for low reving torque with a stroker .
I will only ever poke along just want to easily carry a load and go up hills.
At present I have a strong TP 1600 and with IRS it struggles a bit when full.
So farI have
New AS case
web 218 cam
scat 78 crank
5.4 rods
heavy flywheel
Looking at either going small valve tims heads 37 x35 and centre progressive weber 1 3/8 vintage speed and expecting this to run out of puff at 4-5000 rpm restricted by inlets but be more than enough push my bus along.
Or
DRD stage one 40 x 35.5 heads and twin 40mm Dells 1 1/2 vintage this won't run out of puff i imagine and will produce a fair amount of additional ponies.
I think i would be happy with the first but the :twisted: is tempting me for the second which will involve more $$ especially as I would probably not be able to stay with stock brakes. They are new and work perfectly and i was hoping to get away with them in option one.
Any input would be appreciated.
Mitchell
23 windows ...8 too many!
Memberhus22l
Threads: 36
posted on April 16th, 2015 at 05:19 PM
Read A remarkably similar query on the samba recently .. ;)
Good luck with it. My only thought, is that if you are beefing the engine to carry a load, just as you need power to move a load, you need power to stop it.
Membervwo60
Threads: 71
Mood: good
posted on April 16th, 2015 at 07:07 PM
If you want to get the best out of the engine a set of dual two barrel webers or dellortos, you will gain between 20 to 30 % in torque over a centre mount two barrel, they are really worth the effort, also a lot easier to tune over the progressive weber.
posted on April 16th, 2015 at 07:24 PM
just buy a decent linkage
CSP or Berg
