| [ Total Views: 740 | Total Replies: 5 | Thread Id: 109084 ] |
ashbaxter
Threads: 78
| posted on May 20th, 2015 at 12:44 PM |
Engine Bolts
Hi Guys
I am missing the bolts for engine to gearbox.
Can anyone tell me what size they are supposed to be
Ash
adlbeetle66
A.k.a.: Denver
Under the car.........again!
Threads: 98
Mood: ICH BIN VW NUSS
| posted on May 20th, 2015 at 04:29 PM |
G'day Ash,
[Most of this you probably already know, but here goes.. ]
There are 4 positions where the engine mates to the gearbox obviously, but only 3 of them have nuts, the other one is a bolt and a nut..
Looking from the rear of the car - in at the engine, the bolt on your left hand side at the top will be the one without the nut. This bolt is approx.
75mm long. The bolt screws into a thread on the case.
The Bolt that goes through the starter motor is approx. 120mm long. It has a nut around behind the fan shroud.
Sorry, i can't help too much with the bottom bolts, but hopefully someone else will be able to. The 2 bottom positions have the studs coming through
from the engine. There are 2 nuts that bolt on the underside of the gearbox.
Cheers,
Denver
AA003
A.k.a.: Phill
Threads: 39
| posted on May 20th, 2015 at 05:20 PM |
Bottom bolts are studs only.
Sometimes Volkswagen dealers sell spare parts. Amazing isn't it!
psimitar
Threads: 148
| posted on May 20th, 2015 at 07:20 PM |
posted by AA003
If someone hasn't removed them that is
Bolts are M10x1.5 pitch IIRC but I can't remember the length.
Starter bolt is longer and has a D shaped head as that's meant to stop it spinning when doing the nut up on the engine side. You can use a normal
long bolt but trying to get a socket or spanner to the gearbox side to stop the thing spinning can be tricky.
adlbeetle66
A.k.a.: Denver
Threads: 98
| posted on May 20th, 2015 at 09:09 PM |
Sorry, will update top post.. was doing too many things at once
ashbaxter
Threads: 78
| posted on May 20th, 2015 at 09:49 PM |
Thanks guys
