[ Total Views: 924 | Total Replies: 5 | Thread Id: 109166 ]
Author: Subject:  Cleaning case
Memberhus22l
Threads: 36
posted on May 31st, 2015 at 08:20 PM
Cleaning case
Hey all,
Pulled the oil gallery plugs, need to tap them. I've had machine work done to the case and now de-burred and smoothed things over.
Should I hot tank it?
Idea is to get into the oil galleries and really give it a good clean. Looking to use a cylinder head shop here in Sydney (to tap for the plugs and then tank it).
Secondary question, should I remove the oil pressure relief valves before getting it cleaned? Or leave them in?
Any tips or relevant suggestions would be great.
Membervlad01
Mood: Side ways
posted on June 1st, 2015 at 10:47 PM
nah don't hot tank it, the solution is caustic and will dissolve alloys.
remove all bits from it, i'd use paint stripper and pressure cleaner and then a good water based degrease with pressure cleaner as a secondary stage, blow dry it all out really well.
wear gloves, face mask and respirator with gas cartridge when doing the paint stripper, not good for you.
paint stripper cleans engines parts like nothing else in minutes, strips carbon, oil varnish, grease and everything but the metal.
71 notchback,
Memberhus22l
Threads: 36
posted on June 2nd, 2015 at 12:28 PM
Thanks vlad. I was worried about the case coming out a whole lot lighter than when it went in!
Membervlad01
Mood: Side ways
posted on June 2nd, 2015 at 04:43 PM
yeah they say alloy parts are a no no in hot tanks for that reason.
If you can find someone who ultrasonically cleans parts that's even better!
Comes out surgically clean then.
71 notchback,
Memberhus22l
Threads: 36
posted on June 2nd, 2015 at 05:00 PM
Anyone got a big (really big) ultrasonic cleaner?
Memberdonn
Threads: 428
Mood: LAID BACK AND CONFUSED
posted on June 2nd, 2015 at 05:22 PM
Go to youtube and search " make ultrasonic cleaner " there's a number of how to makes there, on a smaller scale but with a bit of inventiveness you could come up with something on a larger scale.
