| [ Total Views: 616 | Total Replies: 5 | Thread Id: 109217 ] |
JoshJazza
Threads: 1
| posted on June 8th, 2015 at 11:08 AM |
WTB: Link/King Pin Front Axle (Newcastle area)
I am after a standard sized Link/King pin axle
Preferably with everything in tact ready to bolt on, but parts is fine too.
Do not mind if it has adjusters
Text me on 04 0734 5644 |
alansvw
Threads: 138
| posted on June 10th, 2015 at 05:57 PM |
I have a King & Link Pin front end from my 61 ghia but it has disc brakes fitted from 60's. Have removed from car and brakes are off the beam,
also includes sway bay. Not sure what to sell for as happy to keep if my new imported front beam does not pass engineering I may need, but if you make
an offer. I have photos if wanted.
JoshJazza
Threads: 1
| posted on June 10th, 2015 at 10:46 PM |
i have the drum wide 5 stud drum brakes, will they fit straight on? would the beam come with all the tie rods and leaves ect?
photos would be good if you can put it up. |
grumble
Mood: happy all the time
| posted on June 11th, 2015 at 08:23 AM |
Josh if that doesn't work out i have a beam in Taree but will have to check what is missing.
Cheers Les
sgetty
Threads: 117
Mood: yep
| posted on June 11th, 2015 at 10:13 AM |
I have one in Bendy, heading down to pokolbin this weekend but not sure if i will have room unless i strap it the beetles roof rack..
will text ya a pic
alansvw
Threads: 138
| posted on June 11th, 2015 at 03:12 PM |
here was the beam before removal, I had wide five wheels on it. Includes Koni Shocks and master cylinder.
