| [ Total Views: 3167 | Total Replies: 17 | Thread Id: 109409 ] |
tin-bits
Threads: 14
| posted on July 5th, 2015 at 04:08 PM |
Subaru into bus what works for you?
To all who have done this conversion including myself i thought it would a good oppertunity to compile some questions,answers and also pictures.
Of any problems and how you sorted them.
The first one that comes to mind is the cooling and how you set up the radiator/radiators and associated plumbing.
If your replys can be very descriptive it will give everyone a better chance of understanding how and why you did it and of course how good it works.
So as far as the radiator goes if you have installed it under the bus what sort of temps are you getting?
I have just finished my conversion and only done a few laps of the block so not really a good test and that is because i have to sort out the wiring
for the thermo from the ecu.
I went along the lines of the Hellbus build and i think he was running the thermo constantly but not sure of that.
I have read in the Subaru Manual.
Thermostat starts to open 76 to 80 C
Fully open 91C
Question is if 91C is thermostat fully open would that be the optimum running temp before the thermo fan comes on, not sure of the temp that the ecu
starts the thermo.
Radiator cap is stated at being 13 PSI is this what the mojority find success.
I have a single VL Commodore Alloy radiator under the 65 split with 2 thermo fans.
I am sure there are a lot of great ideas and success stories out there and we could all use some informed help.
looking forward to some good info thanks.
Ian
OZ Towdster
A.k.a.: Andrew Westwood
Keen to finish some projects
Threads: 132
| posted on July 5th, 2015 at 05:06 PM |
Great thread idea Ian , it's been a while since most of the aussie ones were done when we had CVD , but with a few getting the urge to continue the
tradition of an EJ subie in the buses , it can never be a bad thing
As for your thermo fans , yes let the ECU control it , have you also fitted a VSS ( Variable speed sensor ) as the ECU will not like life without one
, ie you'll tend to stall when pulling up all the time .
AllenH
Threads: 6
| posted on July 10th, 2015 at 01:14 PM |
Hi I have a jeep cherokee rad roughly 22 inches wide by 31 inches long fully shrouded mounted just infant of the torsion with about a 15 % decline
from rear to front . I had an aluminum shroud built that is fully sealed and encases the outer frame rails with an opening right under the rad to
displace the hot air I hade a small gurney flap mounted just infant of the opening . I have 16 inch fan on the top of the rad blowing down that is
controlled by a standalone adjustable controller mounted on the coolant crossover near the front of the motor. It has stayed under 200 d f until
lately as the outside air temp is roughly 40 d C or 104 f. It cools well in the city stop and go as the fan works quite well but on the highway with
more load and faster speeds the fan either can't keep up or is blocking the airflow Any other suggestions ?The bus is lowered but the scoop on the
front of the shroud should scoop a ton of air Pics to follow
AllenH
Threads: 6
| posted on July 10th, 2015 at 01:29 PM |
Pics of my set up Suggestions ?
AllenH
Threads: 6
| posted on July 10th, 2015 at 01:38 PM |
Rad set up for j22 in 1955 bus
pics
| Error |
AllenH
Threads: 6
| posted on July 10th, 2015 at 01:39 PM |
rad set up for j22 in 1955 bus
pic2
| Error |
AllenH
Threads: 6
| posted on July 10th, 2015 at 01:40 PM |
pic3
| Error |
OZ Towdster
Threads: 132
| posted on July 11th, 2015 at 08:57 AM |
By the look of it you will be having a recirculation issue , ie the air traveling under the bus is taking the easiest path through all the gaps around
the radiator , it needs to be sealed with foam tape or similar and i would suggest reversing the hole angle of the radiator , so the back end of the
radiator is lower than the front ( ie front of bus ) and have the fan suck through the radiator , fans don't work very well at all trying to blow
through the radaitor as most of the air just stalls and dosn't actually blow through the core .
AllenH
Threads: 6
| posted on July 12th, 2015 at 01:49 AM |
re rad
Thx for the reply I have my burp tank or air bleed up high in the engine compartment also I figured that since the whole underbelly area is sealed
with i.e. the cargo floor and sides with the scoop and the gurney flap would create a vacuum area and force the air out the opening in the bottom of
the rad ( the opening is very close to the size of the rad .So as per your suggestions 1 tip down the back edge of the rad towards the back of the bus
seal the sides of the rad with chloroplast Should the gurney flap be at the leading edge of the scoop nearest to the frt of the bus or at the leading
edge of the opening closest to the rad. Thx for your help Al
MR930
Threads: 73
Mood: VW crazy.
| posted on July 13th, 2015 at 07:08 PM |
I'm about to do a conversion to our bay. What is the best radiator to buy and do I need to buy an overflow bottle?
1303Steve
| posted on July 14th, 2015 at 08:38 AM |
Buy whatever radiator you can find at the best price, also see what other people are using and how theirs is working you will need an overflow, its
the best way to get rid of air bubbles.
tin-bits
Threads: 14
| posted on August 21st, 2015 at 12:35 PM |
Hi All,
Finished my conversion but the check engine light turns on with the ingnition but stays on constantly.
Shows no codes when using the 2 blacks or the 2 greens, the light just stays on all the time.
Could I have it wired wrong?
I have the wire from computer I think it's D19 and is marked engine light on the loom straight from the computer to earth side of CEL and power from
ignition to the other side does that sound correct?
Very happy when it goes but boy it's testing my will,power.
Cheers Ian
1303Steve
| posted on August 21st, 2015 at 01:10 PM |
are you using vehicle speed sensor?
kombibob
Threads: 173
Mood: at by cows
| posted on August 21st, 2015 at 03:41 PM |
Hey Ian,
When I did my conversion I did what you did, connected the fan wire to the positive and not the negative side, after I worked out it was wrong my
check light also stayed on all the time( think I fried something)
I swapped computers and the light went out and operated as norm after that.
posted by tin-bits
Hi All,
Cheers Ian
1961 swb buggy
1960 karmann ghia
2012 Skoda Octavia scout
Get down low and go,go,go
tin-bits
Threads: 14
| posted on August 21st, 2015 at 05:06 PM |
posted by 1303Steve
Yes have speed sensor
MR930
Threads: 73
Mood: VW crazy.
| posted on August 21st, 2015 at 07:45 PM |
Well I bought a vl commodore radiator and fitted it with a sealed shroud and a 14in fan. Seems to work ok, temp runs around 74 degrees.
kombi_kid
Good Kid too many projects
Threads: 341
| posted on August 26th, 2015 at 12:06 PM |
Is there a need to run a shroud for the radiator between the rails ? Whats the benefits/need ? Im going to be running a AU falcon rad and fans .
john1960
Threads: 14
| posted on September 2nd, 2015 at 09:34 PM |
Hi guys I have had my ej22 in my 74 bay for about 5 years .Toyota camry radiator fitted on a slight angle .High at the back sloping down a few inches
in the front .Fan between the radiator and the floor .Thermos come on when the computer tells it to .The only heating problem I have had is when the
small hose coming away from the thermostat burst .New hose and back on the road .Mine is done the same way as the ones Aaron (with the VW drag car)
did for both his father and brothers cars when they were converted from vw to subaru .
