[ Total Views: 640 | Total Replies: 2 | Thread Id: 109444 ]
Author: Subject:  WTB - fresh air seal
Memberjakeandco1958
Threads: 26
posted on July 8th, 2015 at 09:11 PM
I need the rubber seal that goes over the fresh air box under the windscreen for a 1971 beetle . It seals the fresh air intake to the front bonnet.
Membergrumble
Mood: happy all the time
posted on July 10th, 2015 at 04:28 PM
This is a square section rubber,measure the clearance from the bottom of the slot on the air box to the bonnet add approx 8mm for compression and measure the length and go to a supplier like Grippy Rubber Products who should be able to assist. This is if you can't get one from Mick's Motors,Tooley Imports,Vintage Veedub etc.
Memberjakeandco1958
Threads: 26
posted on July 12th, 2015 at 08:43 AM
Thanks. I went to Clark rubber and found something very similar. I glued the two ends together and put in. I also managed to get some sponge rubber discs and fixed the fresh air dampers
