| [ Total Views: 900 | Total Replies: 3 | Thread Id: 109513 ] |
JAB-AIR
Threads: 3
| posted on July 20th, 2015 at 06:52 PM |
What Motor with a split gearbox
Hi just wondering if anyone could tell me what will fit up to my 57 beetle split gearbox or am I better off putting a later gearbox in it?
Cheers John
vw54
| posted on July 20th, 2015 at 07:15 PM |
all 6 V motors will fit
if you use 12 volt motor it has a larger dia flywheel which will run on bell housing
adlbeetle66
A.k.a.: Denver
Under the car.........again!
Threads: 98
Mood: ICH BIN VW NUSS
| posted on July 20th, 2015 at 09:37 PM |
I have a 66 beetle with a 6v gearbox. I ran a 1776 12v engine, and all i had to do was grind out the bell housing using emery flapper wheels on the
drill...
I converted the whole car to 12v at the same time.
Here is the thread i started:
http://forums.aussieveedubbers.com/viewtopic.php?tid=106941
Here is my members ride - look about half way down the 1st page
http://forums.aussieveedubbers.com/viewtopic.php?tid=106947
psimitar
Threads: 148
| posted on July 21st, 2015 at 10:38 PM |
with a bit of machining a 6V flywheel will go on a 12v motor. I mean, as the split box can't handle too much of an increase in power then the 180mm
clutch of a 6V flywheel ain't really gonna be an issue.
