[ Total Views: 2258 | Total Replies: 5 | Thread Id: 109598 ]
Author: Subject:  oxyboxer vs type 4
Memberbugzla
Threads: 240
Mood: always happy
posted on August 5th, 2015 at 07:04 AM
oxyboxer vs type 4
okay this is whats happening I have a 1.8 kombi block and a 2.1 watercooled block less heads and barrels but have a set of good type 1 heads whats the better option for performance and longevity help would be great
steve
posted on August 5th, 2015 at 09:15 AM
Oxybxr = $$$
T IV = $$ and low power but good fin area for cooling
Lots to consider but hard to compare as there is heaps to consider in both configurations.
Memberfish26
A.k.a.: benito
Threads: 38
Mood: Ken awesome
posted on August 5th, 2015 at 06:43 PM
Sell the Type 1 heads, put towards building a nice Type 4, whats it going in?
Memberbugzla
Threads: 240
Mood: always happy
posted on August 6th, 2015 at 10:49 PM
going into a beetle fish it was to be blown as well in the future and yes for street use
Super Administratorhelbus
A.k.a.: Pete S
Threads: 312
Mood: In the thinking chair
posted on August 7th, 2015 at 12:10 AM
If it is a beetle, then a larger type 1 engine will fit straight in. In regards to 'blown in future' you cannot do it. A blown engine is built differently to a naturally aspirated engine. The extra pressure of a blown engine requires an initial engine build to have lower compression ratio, as the blower will create the extra bars/ psi of air pressure. If you build a standard engine, and then chuck a blower on it, the compession ratio will be so high that it will ping/ pre detonate so badly, and you will have to back off the timing so much that you will have a standard powered engine.
Memberbugzla
Threads: 240
Mood: always happy
posted on August 7th, 2015 at 07:57 PM
already know about compression and the way fuel ratios /pressure within block so work with a large type one engine with a alloy block not a original due to lack of meat behind cylinder 3 and a bubble top case at that for the stroker crank anything else I need to know or any engine combos that work better then others my mate has a 2275cc turbo motor here in townsville t3/t4 turbo 500cfm draw through and it rockets
[ Queries: 40 ] [ PHP: 14.9% - SQL: 85.1% ]
