| [ Total Views: 1199 | Total Replies: 3 | Thread Id: 109646 ] |
jakeandco1958
Threads: 26
| posted on August 16th, 2015 at 08:49 AM |
Tacho needle bounce 1971 beetle
I've just fitted a Saas 52mm Tacho which works but needle bounces all over the place. Have tried the following. Made sure it was connected to
negative side of coil, fitted a resistor between coil and gauge, checked and changed earth wire, setting on rear is set right. 4 6 8 Other
suggestion is fitting a diode. Any ideas?
shokwave2
A.k.a.: Matt Hamilton
Threads: 28
| posted on August 16th, 2015 at 04:06 PM |
You'll need to install a diode between coil and gauge. I had the same problem.
http://www.thesamba.com/vw/forum/viewtopic.php?t=566900&highlight=diode
psimitar
Threads: 148
| posted on August 16th, 2015 at 11:40 PM |
Yea the diode is needed to allow residual current freewheel to earth
jakeandco1958
Threads: 26
| posted on August 17th, 2015 at 12:44 PM |
thanks. worked a treat. soldered a diode in and now tach works well. cheers
