[ Total Views: 812 | Total Replies: 5 | Thread Id: 109803 ]
Author: Subject:  Reversing light question
Memberbaghall
Ben Hal Outlaw Bushranger
Threads: 131
Mood: Kids think I'm obsessed!
posted on September 17th, 2015 at 08:35 PM
Is it normal for the reversing lights to come on when slipping through the gate for 1st and reverse in a T25 wbx, or is my switch positioned wrong?
68 Baja - It's a growing pain!
58 Baja ute - and the pain spreads!
85 T3 Kombi - still growing
89 T3 Kombi - parts car
Memberpsimitar
Threads: 148
posted on September 19th, 2015 at 05:48 PM
Do you mean when you put the box into 1st the light comes on briefly?
MemberSpecial Air Service
Chief "Gunna"
Threads: 210
posted on September 19th, 2015 at 08:01 PM
not sure....on mine the reverse light wouldn't stay on unless I held the shifter as far left as possible, if I let it go it would switch off.
I had to remove the washer between the switch & the gearbox to allow the switch to screw further into the box & then it would stay on.
Possibly you may need to do the opposite & add another washer or a thicker one?
[size=5]
Click Below
[/size]
[size=6]
Mid North Coast VW
[/size]
Memberbaghall
Threads: 131
posted on September 20th, 2015 at 11:47 AM
It stays on in both reverse and 1st until I take it out of gear.
Memberpsimitar
Threads: 148
posted on September 20th, 2015 at 12:31 PM
OK, so IIRC the switch has a spring loaded plunger that when in the detent for reverse on the hockey stick makes the switch earth as the plunger is fully extended. So If it's fully extended then it needs to screw further into the gearbox. If I haven't remembered corectly then it'll be the other way around and it needs washers to space it further from the gearbox. :)
Chief "Gunna"
Threads: 210
posted on September 20th, 2015 at 01:35 PM
yeah try another washer and see how it goes.
[size=5]
Click Below
[/size]
[size=6]
Mid North Coast VW
[/size]
