[ Total Views: 929 | Total Replies: 15 | Thread Id: 109941 ]
Author: Subject:  WTB - Gene Berg throttle linkage wanted
MemberCamo
A.k.a.: Kev
Threads: 209
posted on October 10th, 2015 at 07:10 PM
Hi all,
just wondering if anyone has one of these (see link below) that they are willing to sell.
Prefer the Sydney area so I can look at it and pick it up at the same time. If elsewhere, please still let me know and also what you want $$
Click here for photo
Cheers, Kev
posted on October 10th, 2015 at 07:30 PM
VVDS
MemberCamo
A.k.a.: Kev
Threads: 209
posted on October 10th, 2015 at 07:40 PM
Excellent, thanks Dave :tu:
MemberOZ Towdster
A.k.a.: Andrew Westwood
Keen to finish some projects
Threads: 132
posted on October 11th, 2015 at 08:39 AM
MMMMMMMM Hope they have more than one
Memberpetemart
Threads: 18
Theme: UltimaBB Pro Charcoal
posted on October 11th, 2015 at 08:47 AM
Why not order one directly from Gene Berg?
MemberCamo
A.k.a.: Kev
Threads: 209
posted on October 12th, 2015 at 07:23 AM
Just don't want to wait that long for it to arrive :smilegrin:
If no one has one or it's to pricey here, then maybe :crazy:
Membervwo60
Threads: 71
Mood: good
posted on October 12th, 2015 at 07:47 AM
I ran one of these on my Ghia, but unfortunately it does push on the carb lever the same both sides due to the bend in the linkages, when under load they can move off centre and changes the amount the carbs open on each side, the other issue is they mount on the fan shroud, not exactly a good place as this moves all over the place as it heats up and cools down, I do not understand the high opinion these are held in, I sold it to a friend of mine even though I told him of the issue, he installed it on his kombi and had the same issues, it was removed and replaced with a better design from CB Performance, I run a both the CB performance and the CSP centre pull linkage, both in my opinion are better than the gene Berge item.
MemberCamo
A.k.a.: Kev
Threads: 209
posted on October 12th, 2015 at 11:08 AM
Excellent feedback thank you and glad you posted this up. The last thing I want is more issues.
Had another friend call me and tell me to go the CSP centre pull, so will look more into that.
Cheers, Kev :tu:
Memberwaltermitty
Mood: Hungry for mor
posted on October 12th, 2015 at 07:23 PM
Cheers, Kev :tu:
I got mine from VS its pretty much a CSP copy with bearings etc, it arrived in 3 days and the quality is second to none.
Mitch
23 windows ...8 too many!
Membervwo60
Threads: 71
Mood: good
posted on October 12th, 2015 at 09:26 PM
I run the CSP on my Ghia with good results, does not go out tune as some people claim with centre mount linkages, I had to modify the CSP linkage to fit my engine but works very well, you can see by the picture I had to lengthen the linkage rod on the drivers side due the tall manifolds
Memberpetemart
Threads: 18
posted on October 12th, 2015 at 09:44 PM
I've run all the linkage types and the Berg is the only one that doesnt go out of adjustment, never moves and had the softest throttle feel.
Sounds to me you may have been running the wrong carb rods, didnt set it up right or had it bolted to a Scat fan shroud.
Membercnfabo
Threads: 140
posted on October 12th, 2015 at 10:38 PM
Why not try the pulley system type of linkage...
Fabo
Membercoletrickle
Threads: 34
posted on October 12th, 2015 at 11:06 PM
Amen Brother
Memberhellbugged
A.k.a.: Daimo Pell
48's and straight cuts
Mood: Couldn't care less
posted on October 13th, 2015 at 05:23 AM
x2
Membervwo60
Threads: 71
Mood: good
posted on October 13th, 2015 at 07:36 AM
By the way it is attached to the fan shroud, any fan shroud is a major problem in its self. correct rods and mounted to a genuine vw fan shroud originally.
posted on October 13th, 2015 at 07:00 PM
[quote
yes the other bits of the engine NEED to be secure
