[ Total Views: 1186 | Total Replies: 6 | Thread Id: 110648 ]
Author: Subject:  T3 Kombi brake upgrade
Memberbaghall
Ben Hal Outlaw Bushranger
Threads: 131
Mood: Kids think I'm obsessed!
posted on March 5th, 2016 at 09:23 PM
Been thinking of using the later model '86-91 model calipers on my '85, are they compatible and am I correct in thinking that the later models had larger pads?
Also what has people used to upgrade the rears to disc brakes?
Would love people's thoughts and experiences.
68 Baja - It's a growing pain!
58 Baja ute - and the pain spreads!
85 T3 Kombi - still growing
89 T3 Kombi - parts car
Memberpsimitar
Threads: 148
posted on March 6th, 2016 at 12:59 AM
Well from what I can see on the VWHeritage website the pre 87 discs were larger in diameter than the later discs by nearly 20mm plus the early used a twin piston non-floating caliper compred to the later single piston floating caliper.
IMO a twin non-floating caliper is always gonna give better performance over a single floating caliper. Modern cars use em cos they're cheap to manufacture.
If you want better brakes then look at vented discs with second hand 4 pot Porsche calipers. Can still pick up up fairly cheap from UK scrappies :)
Membermackaymanx
A.k.a.: Brent
Threads: 97
Mood: Brad'ed Off :td:
posted on March 6th, 2016 at 11:11 AM
Rear Discs in progress
http://forums.kombiclub.com/threads/t3-rear-disc-brake-conversion-kits.51582/
Quote of the week
MemberPAZZAN
Threads: 113
posted on March 6th, 2016 at 01:56 PM
https://www.google.com.au/search?q=vanagon+big+brakes&biw=1920&bih=95...
MemberPAZZAN
Threads: 113
posted on March 6th, 2016 at 01:57 PM
http://www.gowesty.com/product-details.php?id=23870
Memberbaghall
Threads: 131
posted on March 6th, 2016 at 04:05 PM
Thanks for the links guys have put myself down as interested in T4 rear discs. Find it interesting psimitar that the fronts in the later model could be worse than the earlier models.
Memberpsimitar
Threads: 148
posted on March 7th, 2016 at 01:21 PM
Not necessarily worse in terms of day to day ability but in terms of outright performance they're mediocre.
The single piston sliding caliper is given a much larger piston diameter so that it has similar clamping force to the twin piston earlier caliper. Then they increase pad surface area to increase the amount of friction available but compared to a multiple piston caliper the sliding caliper can never compete just due to how the clamping force is spread across the pad.
In multi piston calipers the braking pressure is more evenly distributed over the pad leading to better brake feel and more even pressure onto the disc surface. The more evenly the pad is pressed against the disc then the larger area of friction compared to a single piston that will have reduced pad to disc pressure towards the edges of the pad. A 5mm steel back plate may seem quite thick but under such pressures you'd be surprised how much flex there is.
It's kinda funny how people don't realise how costs are being cut in high end performance vehicles like the sporty Mercs, Audis and Jags. They use discs the size of dustbin lids but use the cheap to manufacture single piston caliper compared to 5 or more years ago when they still used 4 pot calipers with smaller discs that could still out perform the larger latest single pot brakes :)
