[ Total Views: 1026 | Total Replies: 7 | Thread Id: 110779 ]
Author: Subject:  What spark plugs
Memberroofchop
Threads: 37
Mood: In the mood for a beer usually
posted on April 3rd, 2016 at 06:23 AM
What spark plugs
So what plugs are you all using in you modified VWs ?
Been reading conflicting reports re modern (iridium etc) plugs not working as well in our motors.
Doesn't really make sense.
Dave
posted on April 3rd, 2016 at 08:01 AM
what heads do you have what size engine what compression
Membermodnrod
Threads: 50
Mood: Old School Volksies!
posted on April 3rd, 2016 at 09:28 AM
Denso Iridium for me. Get your heat range correct, get the compatible thread/seat/diameter/length, then screw it in and ignore the things for years on end.
Done.
Memberroofchop
Threads: 37
posted on April 3rd, 2016 at 10:13 AM
Cheers,
1641 single port heads (stock), dual ICTs engle 110, lifters hd springs/retainers
extractors, pertronix flame thrower, SVDA dissy, and 1mm spacers between head and barrels (dunno compression!)
Yup seems silly having fancy ignition system and using antique plug technology!
What heat range do I need?
Dave
Membermodnrod
Threads: 50
posted on April 3rd, 2016 at 02:03 PM
Heat range NGK 6 or Denso 20 should do nicely.
Super Administratorhelbus
A.k.a.: Pete S
Threads: 312
Mood: In the thinking chair
posted on April 3rd, 2016 at 10:31 PM
Stock distributor with aftermarket heads. Just using standard NGK 12mm thread
Memberpsimitar
Threads: 148
posted on April 4th, 2016 at 07:04 PM
Weird that you've got 1mm barrel spacers for std 1600 heads but sounds like a low compression motor so will need a cool plug rating as ModnRod said.
Memberroofchop
Threads: 37
posted on April 5th, 2016 at 06:22 AM
The heads are 1300 SP, my old mate Al from Stokers VW said to put the spacers in when I went to 1641 or it would run on.
So I will get some posh plugs, heat 6 or 20 of the correct length and width.
Dave
