[ Total Views: 506 | Total Replies: 0 | Thread Id: 111181 ]
Author: Subject:  FS QLD - 1200 Engine Cases & Parts
Memberconankombi
Threads: 30
posted on June 25th, 2016 at 03:32 PM
FS QLD:
2 x 1200 engine cases 7872764 ('64) 8884592 ('63) - $75 each (comes with oil pump & alt. stand)
1 x 1600 DP dual relief case AD059535 - $100neg Note that this has some wear around the oil sump at the base (photos upon request)
1 x 1600 DP dual relief case AS21 - $150neg Note this does not come with cylinder heads studs
2 x crankshaft - $40 each
2 x camshaft (1 gear is not useable) - $40/20 (lobs are perfect)
8 x conrods - $10 each
4 x heads ending in 371C - $75 sold as set of 2 (requires reconditioning and new valve springs etc)
Also have a 1200 case and internal parts but not cleaned D0752867 ('66) and comes with heads ending in 373B - $100
All have been cleaned and checked and no visible cracking. 0434 638 632
