[ Total Views: 830 | Total Replies: 1 | Thread Id: 111255 ]
Author: Subject:  1500 Pistons on 1200 rods???
Memberdanza85
Threads: 10
posted on July 10th, 2016 at 01:24 PM
Is there any way 1500 Pistons will fit 1200 rods?
I see that the pins from 1500 Pistons are larger, but any bushes etc that help in conversion?
Membersander288
"Bolt-on Master"
Threads: 183
posted on July 10th, 2016 at 06:34 PM
Not sure what you're after here, but the 83mm pistons from the 1500 motors (69x83) won't fit the 1200 40Hp engines.
However, if you want to get 83mm bore pistons onto the 40Hp these already exist without buggerising around with bushes and mismatched parts, see link below
http://aapistons.com/collections/vw-piston-liner-kits/products/83x64mm-1200cc...
BMW R65 LS
1967 1300 Deluxe
Swing-axles FTW :!:
