[ Total Views: 890 | Total Replies: 2 | Thread Id: 111290 ]
Author: Subject:  stud diameter in type 1 case
Memberadams kombi
Threads: 23
Mood: Short of time!
posted on July 17th, 2016 at 10:06 PM
Hi all, just a quick question. I'm doing a quick rebuild on my type 3 notch, 1600 engine. I have bought another 1600 upright engine that was in a kombi with a cracked case as it had an engle cam in it, which I intend to use. Putting the two cases next to each other, the upright has larger diameter barrel/head studs fitted.
Would these have been fitted as an upgrade or is there some diffenence that larger studs are in place? Also is it worth fitting the larger studs to the case I'm going to use? The old engine was leaking oil pretty badly and all gummed up hence giving it a tidy up and replacing the pistons barrels, but it was running without any major issues.
Thanks in advance. Adam
Cheers, Adam
73 Microbus, restored
72 Notch, awaiting restoration
posted on July 18th, 2016 at 07:24 AM
the earlier engines had the larger studs 10mm
The newer engines had the smaller studs 8mm
the smaller studs with case inserts are the better of the 2 cases as the bigger studs tended to pull the threads after years of use
if your using the upright case for the type 3 engine I would check also if it has the dip stick oil
Memberadams kombi
Threads: 23
posted on July 18th, 2016 at 07:38 AM
Much appreciated
Thanks for clarifying that,
I will be be using the type 3 case (upright one is the one that is cracked) there are a few slight differences I could see with mounting points either side of the oil pump and oil pressure sender unit etc.
All good.
Cheers, Adam
