| [ Total Views: 1331 | Total Replies: 7 | Thread Id: 111330 ] |
ultrasuede
Threads: 23
| posted on July 24th, 2016 at 08:10 PM |
Best distributor for 34 pict 3 1600cc combo
Very confusing using the voogle machine to find the answer to this. I ha e a 34 pict 3 and a 205 vacuum advance dissy. Probably going to go with an
electic dissy, but what one? Thanks
1961 Bug owner
waltermitty
Mood: Hungry for mor
| posted on July 24th, 2016 at 08:20 PM |
you have the best combo available what is your problem with it?
23 windows ...8 too many!
ultrasuede
Threads: 23
| posted on July 24th, 2016 at 08:49 PM |
I cant seem to find this serial number on any references. Its sibgle vacuum, but the 34 pict 3 has 2 vacuum ports
| Error |
1961 Bug owner
waltermitty
| posted on July 24th, 2016 at 09:44 PM |
no should only have 1 if there is a second it could be a late 34 pict with EGR port
http://www.angelfire.com/tx2/ntnb/Carb_Instructions.htm
modnrod
Threads: 50
Mood: Old School Volksies!
| posted on July 24th, 2016 at 11:09 PM |
http://forums.aussieveedubbers.com/viewtopic.php?tid=104940&page=1#pid982805
Hope it helps.
BRUTUS
A.k.a.: et tu, Brute
Threads: 17
Mood: ACE 30 FOR SALE!
| posted on July 25th, 2016 at 05:17 PM |
The 34 PICT 3 should have ONE vacuum advance connection... Yes Ultrasuede, if you connect the vac. advance properly & it is all working, should
be a good combo. as W'mitty said.
If there is another vacuum port, it will be meant to go to the air cleaner (or possibly manifold, just below the carb. mount, on some earlier
models? -- why that was done I can't understand). (& the JFUR-4 / 905 205 Z should be DUAL mech./vac. advance?)
ACE 30 & 40 oils: specifically engineered for your Air Cooled VW
delivered (free del.) throughout Yarra Valley / Ranges, & Gippsland areas. Also ACE 20, 50 & 90.
FOR SALE: ACE 30, 40 etc. Oil formulations & Trade-names.
hulbyw
Threads: 133
Mood: I'm OK, RU?
| posted on July 25th, 2016 at 08:38 PM |
Beetles with the later style plastic air cleaner housing needed a vacuum port for the dizzy and one for the air cleaner
BRUTUS
Threads: 17
| posted on July 26th, 2016 at 11:45 AM |
2 pics shown at:-
http://forums.aussieveedubbers.com/viewtopic.php?tid=105590#pid987221
On the 34 PICT-3/4/5, the vac. advance port (a brass tube or spigot) is the small tube on the LHS just above the bypass (large) screw used to adjust
the idle speed. The vac port (similar small brass tube) at the REAR (and rear of car) is connected to the air-cleaner as shown in the picture on
previous post (link above -- 4-connection type shown -- earlier plastic air-cleaners had two connection points on the air-cleaner).
