[ Total Views: 908 | Total Replies: 1 | Thread Id: 111507 ]
Author: Subject:  Ratio rocker set up
Memberhus22l
Threads: 36
posted on September 2nd, 2016 at 09:04 AM
Ratio rocker set up
hey all,
I'm setting up new 1:1.25 rockers (adjuster at the pushrod end). My side clearance is excessive. I need to add shims to bring into range (0.003-005").
Can I use the shims/washers from a stock rocker set up? (Obviously not the wavy ones) Or are these more like washers than shims?
If I'm better off getting specific shims, anyone got some spare shims they don't need?
Any suggestions?
posted on September 2nd, 2016 at 03:33 PM
get the correct shims
the stock ones sometimes don't fit he new ratio shaft as they are slightly bigger
