[ Total Views: 1907 | Total Replies: 14 | Thread Id: 111542 ]
Author: Subject:  oil filter gasket help
Memberpv370
Threads: 38
Mood: Southern Comfortably Numb
posted on September 8th, 2016 at 06:05 PM
so its time to do the first oil change on the type3 panelvan since the engine rebuild. a couple of dumb questions..........
i recall reading that the cardboard oil filter gaskets need to be sprayed with something to make them non porous...
whats its called... where do i get it..... how do i use it....
any other tips or tricks so it doesnt leak....
also what are the torque settings of the centre drain plug and the smaller dome nuts????
thanks in advance
Membergrumble
Mood: happy all the time
posted on September 8th, 2016 at 09:09 PM
Put them on dry, if they need sealant they aren't good quality. There are copper gaskets under the dome washers and the sump plug,don't forget to replace these with new ones that should be in the strainer kit.
posted on September 9th, 2016 at 07:23 AM
yes put on dry
make sure the plate is not distorted around the 6 stud holes make it flat if its warped
Membermodnrod
Threads: 50
Mood: Old School Volksies!
posted on September 9th, 2016 at 09:53 AM
If you have a flat plate, and a flat sump, and a nice good quality gasket, then dry works well.
Unfortunately getting all 3 at once is unlikely.........
http://www.ebay.com.au/itm/Aviation-Gasket-Sealant-Form-A-Gasket-50ml-3J-Loct...
Memberpv370
Threads: 38
posted on September 9th, 2016 at 08:53 PM
thanks for the replies
ok so i have some loctite no3 ........... should i use it anyway.......... looks like the filter gaskets had some sort of sealer on them previously......
better to be safe than sorry how tight should the dome nuts be ?????
Memberhulbyw
Threads: 133
Mood: I'm OK, RU?
posted on September 9th, 2016 at 10:25 PM
Any sealant you use will be a PITA to get off next oil change. Best to leave it dry. My Idiot Manual says 5ft lbs torque on the nuts. Unless you are into working on push bikes, you probably won't have a torque wrench that goes that low. Just do up firm, but don't lean on them. Drain bolt is 25ft lbs
posted on September 10th, 2016 at 07:13 AM
leave dry that's why you have paper gasket so they crush to seal
Memberpv370
Threads: 38
posted on September 10th, 2016 at 10:31 AM
got it..........
nice to have the right info........
have always used them dry but for some stupid reason the engine rebuilder has used what looks like silicone ?????????????
i will put it together dry and see what happens
thanks for all the input
MemberHappyDaze
A.k.a.: Greg Mackie
Superannuated
Threads: 141
Mood: Happy enough
posted on September 10th, 2016 at 12:08 PM
If you don't have the correct 'acorn' nuts, Nyloc nuts will do to stop the oil seeping down the threads...and use new copper washers.
Memberpv370
Threads: 38
posted on September 10th, 2016 at 03:17 PM
yeah i have the dome nuts and a new gasket set
just done the filter...............what a PITFA it was to get the left over bits of the gasket off the sump.
know im starting to think that the gaskets had silastic on them why???????
was it because the sumps not flat ???????? i would think an engine rebuild would include checking that......... in this case who knows.............
time will tell i guess
posted on September 10th, 2016 at 07:33 PM
yep sump plate not flat
the most over look item always causes leaks
Memberpv370
Threads: 38
posted on September 11th, 2016 at 05:30 PM
ok so gaskets done with no sealant.... so far so good..... approx 20 mile test run with no leaks...... will check in the morning if any drips on the garage floor.........
thanks for everyone input
Memberpv370
Threads: 38
posted on September 12th, 2016 at 05:06 PM
pic
dry as a chip sorry for the crappy pic
thanks to all
posted on September 12th, 2016 at 06:13 PM
some people love silicon and others love permatex or other gasket cement.
I have always used the non drying permatex or aviation gasket cement..
It does make a gasket change Harder to clean etc....
another good hint: You can You silastic on exhausts, headers and manifolds as it WILL handle all that heat and does an excellent job of sealing any clean exhaust surfaces...
I didn't believe it at first, after being told that a mechanic fitting header exhausts etc used it for years to fix any gaps. I have used it for over 6 years now without any problems...
MemberHappyDaze
A.k.a.: Greg Mackie
Superannuated
Threads: 141
Mood: Happy enough
posted on September 12th, 2016 at 07:14 PM
If you must use silicon on exhausts, and there's an oxygen sensor in the system, make sure it is oxygen sensor safe.
[ Queries: 40 ] [ PHP: 15.8% - SQL: 84.2% ]
