[ Total Views: 1000 | Total Replies: 2 | Thread Id: 112123 ]
Author: Subject:  Shifter Problem
MemberBlasterTheRedBajaBug
Threads: 78
Theme: UltimaBB Pro Charcoal
Mood: Playing the cards, like they were what I wanted
posted on February 6th, 2017 at 07:38 PM
Shifter Problem
Hi all,
I have just gone to put Blaster in gear to test the transmission and it does go into gear properly but the shifter shaft i guess you would call just rotates even in gear but the shifter knob moves with it, is this normal?
Nobody can drive you crazy, unless you give them the keys.
Memberpsimitar
Threads: 148
posted on February 6th, 2017 at 09:51 PM
If the gear stick itself can rotate then that means the pin in the sticks fulcrum ball has broken off or come loose and dropped out. I'm not exactly sure why it's even there beyond the fact that it stops the stick rotating so the cranked shape of it stays in the one place.
Threads: 78
posted on February 6th, 2017 at 10:13 PM
Oh ok so it is fixable I was sorta freaking out there for a minute.
