[ Total Views: 1704 | Total Replies: 7 | Thread Id: 113186 ]
Author: Subject:  Kafer Cup Brace
Memberpsimitar
Threads: 148
posted on April 11th, 2018 at 09:37 PM
Kafer Cup Brace
Hello all,
I tried using teh search function but couldn't find the post about the person who was having made and selling the 3 and 5 bar kafer cup braces.
Anyone know who it was or have a link?
Cheers :)
Memberhellbugged
A.k.a.: Daimo Pell
48's and straight cuts
Mood: Couldn't care less
posted on April 11th, 2018 at 11:18 PM
Torrens, not making them anymore
posted on April 13th, 2018 at 08:35 AM
I made my own using moly tube and some rose joints that I bought from UK eBaY. they are 3/8"x 7/16" UNF Male Right & left Hand Thread Rose Joint, I bought them from these guys, they were much cheaper than buying them here https://www.ebay.com.au/usr/mcgillmotorsport?_trksid=p2057872.m2749.l2754
buy the weld in slugs from them as well and get moly tube to suit
MemberCH5353
Threads: 33
posted on April 13th, 2018 at 04:58 PM
I made a cheap set using using bits and pieces , worn out tie rod ends for the LH & RH thread, bolts, 5mm flat bar and 13mm ID tube.
Welded some flat bar to threads, made some brackets for top shock mounts with longer bolts and rear gear box mount on end of tuning forks
1 long tie rod with modified ends for between shock towers and 2 short tie rods from shock towers to gear box mount
Might look agricultural but with a quick spray of black paint and where it is on car no one can see, its a rally car so stone chips etc are normal
Have not used it yet but if not strong enough I can always weld a length of angle to stiffen up
67 T1 BJ IRS
61 T1 Karmann Cab
posted on April 13th, 2018 at 05:48 PM
I found some pictures of my homemade Kafer Cup bars, Ive since made it a 5 bar setup
MemberRodPenrose
A.k.a.: Rodney Penrose
Threads: 330
Mood: GETTING FASTER
posted on April 13th, 2018 at 07:05 PM
http://rodpenroseracing.com.au/parts/270-kafer-bar-used-to-stiffen-the-rear-e... , in stock, Rod.
More boost + More fuel = More power
1968 Beetle fastest run 8.96 sec @ 161 mph 4th Nov. 2001
2010 New Beetle 8.12 sec on 8th march 2014
http://www.rodpenroseracing.com.au
MemberCraig Torrens
A.k.a.: Craig Torrens
Threads: 347
posted on April 14th, 2018 at 07:10 AM
https://forums.aussieveedubbers.com/viewtopic.php?tid=68032&page=3
I might be making another batch.......how much of a hurry are you in ?
MemberWhitty
Threads: 28
Mood: so happy I could shit
posted on April 14th, 2018 at 03:54 PM
Would be keen Craig if you were to make a new batch.
