| [ Total Views: 1889 | Total Replies: 9 | Thread Id: 113512 ] |
Syngear
| posted on January 29th, 2019 at 09:20 PM |
Syngear Razor Blade Drive System Price: 128 AUD
- innovative steel belt application
- high strength carbon steel used for belt members punched in Solingen Germany
- belt members fixed by clips installed by hand
- clips made of copper beryllium alloy and coated with black nylon
- pulleys made of cast nylon useable up to 120 degree Celsius
- innovation useable for all low power belt applications
- patented in Europe, USA, Japan and some more countries
- the VW Beetle Engine was just the demonstrator (the system was not specially invented for the VW Beetle Engine)
- useable for type 1 engines with DC Generator (the test engine used this type of generator)
- the belt consumes nearly no deformation energy
- the system operates with a very low pre-load (you can rotate the generator pulley by hand at engine shut down)
- about 10 years of testing to understand the physics of the belt system
- normal grease not useable therefore special grease developed
- easy to install with just two Allen Keys
- set comprises two belts
- 128 AUD low introductory price (15% off) by using discount code LA29SQZ1OY89 including shipping
- http://www.youtube.com/watch?v=hnFONBehXBE
- http://www.syngear.co.uk
| Error |
| Error |
| Error |
| Error |
vw54
| posted on January 30th, 2019 at 05:51 PM |
Apart from the looks whats the main advantage
barls
A.k.a.: Mr indestructible
Causer of Chaos and Mayhem
Threads: 296
| posted on January 30th, 2019 at 07:40 PM |
considering they have 6 other threads advertising this same product. i wouldn't expect a reply
vw54
| posted on January 31st, 2019 at 06:57 AM |
This will make them there first million dollars
AA003
A.k.a.: Phill
Threads: 39
| posted on January 31st, 2019 at 07:27 PM |
posted by vw54
Stops people puting their fingers in the pulley.
Sometimes Volkswagen dealers sell spare parts. Amazing isn't it!
vw54
| posted on January 31st, 2019 at 07:32 PM |
15 bucks for a fan belt is cheap
Syngear
| posted on February 1st, 2019 at 04:18 AM |
Some advantages:
- A normal v-belt at maximum load takes about 500 Watt additional power for driving the fan / generator unit of the VW Beetle for overcoming the
deformation force.
- The steel belt gives the engine more freedom for speeding up, because the force transfer is smoother than when running a rubber belt.
- The steel belt has no problems with high temperatures.
- No problems of loosing the belt at high engine speed when running tuned engines because very low weigth and therefore low centrifugal force.
- Very low industrial foot print because belt can be assembled by hand.
vwo60
Threads: 71
Mood: good
| posted on February 1st, 2019 at 09:42 PM |
You could try getting it reviewed in the Australian VW magazine.
posted by Syngear
Some advantages:
deformation force.
Syngear
| posted on February 1st, 2019 at 10:43 PM |
Thank you very much for your proposal. I have contacted the magazine.
montybug
Threads: 8
Mood: Just startin'
| posted on February 10th, 2019 at 01:49 PM |
120 deg Celcius Nylon for pulleys may not be good enough for these aircooled buggers i imagine it gets quite hot in there sometimes.
