| [ Total Views: 454 | Total Replies: 3 | Thread Id: 13984 ] |
de_ja_vu
Threads: 19
| posted on October 1st, 2003 at 08:16 PM |
external oil cooler - help!!
anyone has any idea or pictures of location for external oil cooler on a bug?
10x
vassy66T1
A.k.a.: Marcus Vass
Wow ... are U reading this?
Mood: Happy to own a VW
| posted on October 1st, 2003 at 10:57 PM |
Above the gearbox is a reasonable spot. Not a lot of room to play with, but out of harms way.
LOWBUG
Threads: 33
Mood: OUT OF CONTROL
| posted on October 2nd, 2003 at 09:41 PM |
Cooler
I run a cooler above the drivers side axel its about 10" x 8" with a thermo fan attached to it, I got the fan at a bike recker so its tiny
and does the job well.
On a 40-45 degree day I don't get over 110 degrees.
BiX
Threads: 154
| posted on October 3rd, 2003 at 12:32 PM |
I run a largish bugpack one, Its a 48 plate i think(?). the top is mounted at the corner above the gear box (where it goes from horozontal to vertical
under the seat) and then the cooler runs back at 45 degrees and is supported by 2 rods. Works really well and never seen it go over 90 degrees, even
in summer on the track, (8.5 :1 comp, 1776, etc) |
68AutoBug
posted on October 3rd, 2003 at 12:47 PM |
External oil coolers... great mate !!
de_ja_vu
there are many different ways of doing an external oil cooler. There is the oil pump plate... or the plate over the original oil cooler base with a
thermostat that opens the external oil cooler when the temp gets Hot !!... most are installed above the gearbox or axles... some have electric fans
and others depend on the cool air flowing under the car... the best part is:
Most external oil coolers also incorporate an external engine oil filter..... and help extend the life of Your Engine.. GREAT!!
2443TT
A.k.a.: Ian
Threads: 69
| posted on October 5th, 2003 at 03:06 PM |
I went for the above the gearbox/under the parcel shelf option, and use a 96 plate cooler with thermal fan.
It was a very tight fit, but works fantastic.
Cheers,
Ian.
