| [ Total Views: 422 | Total Replies: 3 | Thread Id: 14055 ] |
Robo
Threads: 120
Mood: Oval madness
| posted on October 3rd, 2003 at 06:48 AM |
FUEL TANK RESTORATION
HI Fellow addict's
I want to get the tank off my Beetle resto'd the tank is sound with no holes, but it has the usuall rust scale inside. How can I get it cleaned
and resealed, I have heard that Radiator repairer's can clean them out, and I know POR market a two pack tank sealer.
I am on the gold coast.
Any suggestions on how to restore it are very welcome!
Rob......
Boxer Power
vw54
| posted on October 3rd, 2003 at 07:56 AM |
Rob
I did the ones for my 65s last year and found the best way to do is as follows. I dont like using the seallers or or products would rather have solid
metal there.
1. remove the outlet nozzle and tape up the thread with some plastic tape so thread dont get damaged
2. have outside of tank blasted to remove paint and find rust holes
3. depending on pin holes found either siler braze up or cut the whole section out and make new with sheet metal
4. if only a few holes fill tank with some soapy water and nuts and bolts and shake the crap out of inside it to remove flaking rust and scale
5 wash several times and remove nuts n bolts
6 hopefully no pin holes i blanked outlet hole up and sat tank on saw horses with a few litres of fuel inside to see if there were any leaks through
pin holes.
7 undercoat and paint.
Andy
Andy's Adventures
Threads: 181
Mood: Happy Man
| posted on October 3rd, 2003 at 10:28 AM |
Hey Mate,
I remember looking into something similar for the tank on one of my bikes years ago. I never went ahead with it, but a number of bike shops had
products you could use inside the tank, so you might be able to look there also.
Like Dave all I have done in th past is put some clean coarse gravel in the tank (I did it dry) rolled around for a while, removed then hosed out, let
dry in the sun over a full sunny day, rinsed out with fuel.
Cheers Dude.
Andy
:thumb
modulus
A.k.a.: Peter Hill
Mood: modular
| posted on October 3rd, 2003 at 10:38 AM |
And to state the obvious, welding/brazing should only be performed after ensuring the tank is full of something other than pertol fumes... e.g. water
vw54
| posted on October 3rd, 2003 at 11:11 AM |
Yep I was presuming that the tank had been sitting around for a while and had been washed out a few times with soap n water... before any welding or
grinding
Lastly yes Rinse out with fuel until all grinding and welding junk has been removed.
Make sure you replace the Stock tank filter in the outlet nozzle and put a cheapy plastic paper filter before the fuel pump in the fuel line before
fuel pump.
Ive done this with all my car n never had fuel problems, replacing the paper plastic filter every 12 months or so.
Robo
Threads: 120
Mood: Oval madness
| posted on October 3rd, 2003 at 03:16 PM |
Thank's Guys
Have to get off my arse and do it now!
Rob......
Boxer Power
