[ Total Views: 949 | Total Replies: 1 | Thread Id: 14816 ]
Author: Subject: solex 31-pict-4 high idle
Memberde_ja_vu
Threads: 19
posted on October 22nd, 2003 at 09:33 AM
hello
i have a problem with a solex 31 pict 4 carb, it idles on high rpm (around 1,200) with the idle screw close and the choke lever fully open(warmed up engine), i've already replaced the mixture and idle screws o rings but still having the same problem, any ideas anyone?
thanx in advance
shlomi.
posted on October 22nd, 2003 at 09:37 AM
is the butterfly binding???
Is the throttle arm returning??
A lean leak would cause it to idle high
Memberde_ja_vu
Threads: 19
posted on October 22nd, 2003 at 10:15 AM
what do u mean butterfly?
all the mainfold gaskets are *new* and the engine doesn't seems like running too lean (no pings backfires or anything) it's working nice and smooth but very high on rev.
the throthle arm returns with no problem..
actaully it seems like too reach... but the mixture screw is set up correctly... (about 3 spins out)...
posted on October 22nd, 2003 at 10:32 AM
Butterfly = throttle plate
If that is binding and being held open it would cause it to idle high
