[ Total Views: 1764 | Total Replies: 15 | Thread Id: 14928 ]
Author: Subject: quick shift kit
Memberrobnjo
Threads: 254
Mood: its tricky tricky tricky
cool.gif posted on October 24th, 2003 at 08:55 PM
quick shift kit
are those quick shift kits any good?are they hard to put in?(Sbug) I saw them on "mickmotors" site 2 months or so ago.
any help out there?
posted on October 24th, 2003 at 09:31 PM
They shorten the throw buy say 40%
They are easy to put in. You just put the plate under the shift plate.
Then you take your gear knob off and remove the spring and plate. Put the mushroom on and the other bits back. Then you bolt it back on the shift plate and extender plate.
If you like a sport shift they are great. You should also replace the rear g'box coupler at the same time. This will really tighten up your shifts. The short shift kit and a worn coupler will eccentuate(sp?) how worn it is.
You wanna check your shift rod bushing just in the tunnel. If this goes the gear stick gets an annoying rattle. Fiddly to change but easy-ish.
All 3 at once and under $50 and a mornings work. (crossed fingers)
Memberrobnjo
Threads: 254
posted on October 24th, 2003 at 09:51 PM
so am I doing this job in the car under the rubber boot at the bottom of my gear stick right?:(
Member56astro
Threads: 74
posted on October 24th, 2003 at 10:00 PM
Yeah
Both the quick shift kit and rod bushing are done through where the shifter sits in the tunnel.
The rear rod coupler is done at the access panel at the rear of the tunnel, from inside as well.
35MPG on 101.3kPa
posted on October 24th, 2003 at 11:03 PM
Just try the short shifter first, it may be all you need. Depends naturally on how much work your shift rod has done..
It may be OK...
The short shifter is simple to put in..
just mark where the original shifter plate is before You undo the bolts, so You can put it all together in the correct spot, as if You don't know how to align the plates etc...
You will be hitting reverse all the time...
best of luck
Memberrobnjo
Threads: 254
posted on October 25th, 2003 at 06:30 AM
thanks guys I'll have a crack at it:thumb
MemberStanley
Threads: 270
posted on October 25th, 2003 at 09:38 AM
best of luck
You can't hit reverse unless you push the button for the reverse lockout.
I had to play around with mine a bit to get it into reverse nicely.
Only draw back is it accentuates the inherant beetle problem when going from third back to second.
All you need is a quick shift for your leg and your laughing.
MemberAdam_C
Threads: 164
Mood: could be lower
posted on October 25th, 2003 at 05:09 PM
Hi Adam some prices:
Front bush split----$5.60.
Shift couple complete w/cage-----$15.30.
Quick shift adpt----$6.50 prices include GST.
from an remail .... under $30... im ordering this asap ;)
Adam
Adzslick@iprimus.com.au
Memberrobnjo
Threads: 254
posted on October 25th, 2003 at 08:27 PM
from an remail
WHAT THE!:jesus
MemberAdam_C
Threads: 164
posted on October 26th, 2003 at 03:53 PM
an email...... typo
ya smartass!!!!
Adam
Memberrobnjo
Threads: 254
posted on October 26th, 2003 at 05:06 PM
ya smartass!!!!
so you know me then ?:D
Memberrobnjo
Threads: 254
posted on February 8th, 2004 at 07:19 PM
OK,one of the jobs I didn't do but am going to do in the next few days.picked up a shifter kit of the "mickmotors stand"at dubz($5)I go and chase up the bush and coupler monday.
will see how I go:jesus
Rob
shocked.gif posted on February 9th, 2004 at 02:22 PM
Reverse instead of 2nd gear....
best of luck
68autobug
Kafer69
Its very easy to hit reverse if the flat plate with the edge isn't in the correct position... and this is With OUT the quick shift kit..
same rule applies with the quickshift kit..
Memberjettn
Threads: 3
posted on February 9th, 2004 at 11:17 PM
Hey guys a mate of mine helped me with putting on the quick shift kit today, let me tell you it does get a bit frustrating having to find the sweet spot where to lock down the plates to get all the gears correctly again.
Mine is also having trouble going from third to second is this just a beetle thing or what? i would love to know.:(
Memberratty 63
A.k.a.: Rossco
Threads: 74
Mood: Just cured my shed envy! :D
posted on February 10th, 2004 at 01:25 AM
Yep, its usually just a VW thing actually. Most vehicles I have driven that have a few miles on them (ie: almost all of them) have a bit of wear in the gearbox. Unless you slow down until you feel that you are almost going too slow in 3rd before changing back to 2nd it will usually grind (at best). Doesn't do it in any other gear, or when shifting from 1st to 2nd.
Interstingly, the g/boxes in out companies Suzuki swifts (all 76+ of them!)will usually start to become difficult to downshift from 3rd to 2nd a couple of weeks before the 'boxes give up altogether. Apparently caused by a failing syncro on 2nd - I don't know how the internals of the 'boxes work, but I would have thought that this would cause problems when upshifting too....
So, if you are having no troubles with shifting up through the gears and only issues going back from 3rd to 2nd, then I feel that you could safely put it down to a worn (but still useable) 'box.
Just my 5c! :)
R
40hp, 6V and ...er... slowly making improvements :lol:
It's nice to be important, but it's more important to be nice!
Founding member of the Gold Coast Dub Club Inc. :)
MemberMad Manx
A.k.a.: Travin C.
KombiKroozin
posted on February 26th, 2004 at 08:06 PM
I've got a quick shift kit with new coupling on my manx and I love it! It adds huge pleasure to my driving when I can quickly snap thru the gears- Best $50 I spent so far I recon. I two have the crunch from 3rd down to 2nd- I think the shift kit makes it more noticable as the driving style does change a bit with a sportier shift- on advice is to slow down a lot more before changing between gears- it wont do it then.
http://users.tpg.com.au/travin/kombi/Komanxcab.jpg
- '71 Kombi (Died 24/11/05:sniffle: ) - '65 manx (smick) -'63 beetle (bent) -'73 Singlecab (new to the stable)
MemberHotRodMatt
If it's old or rare - cut it!
Threads: 361
posted on February 27th, 2004 at 08:02 AM
Just double shuffle when going from 3rd to 2nd.
Memberrobnjo
Threads: 254
posted on February 27th, 2004 at 07:15 PM
ok got the kit in today :cool: also bought a new bush and a new coupling but have'nt put them in,beside where the hell does the bush go?? I think I know where the coupling goes...
[ Queries: 40 ] [ PHP: 17.4% - SQL: 82.6% ]
