| [ Total Views: 528 | Total Replies: 10 | Thread Id: 15635 ] |
kombi_kid
Good Kid too many projects
Threads: 341
posted on November 11th, 2003 at 03:21 PM |
what to replace when rebuilding motors?
ok people
tell me what you like to replace when rebuilding your type 1,type3 and type 4 motors!
rhys
vw54
| posted on November 11th, 2003 at 03:24 PM |
all the worn bits
kombi_kid
Threads: 341
| posted on November 11th, 2003 at 05:38 PM |
whats happens if its just a strip down just for fun your not noticing anything being worn!
rhys
Andy
Andy's Adventures
Threads: 181
Mood: Happy Man
| posted on November 11th, 2003 at 06:16 PM |
Do you have tool accurate enough to measure the wear? Have to read the manual to see if the wearing parts are in spec?
Wear isn't always 'visible'
As Dave said, all the worn bits
vw54
| posted on November 11th, 2003 at 06:28 PM |
Rhys it depends what you intend doing with the engine....
Are you stripping it for fun and the learning of how an engine goes together if so get some measuring tools and learn how to measure to find the
worn bits.
this isnt a bad excerise to do if you dont intend on running the engine in a car you are not going to keep for a few years.
If your building an engine to last well lets see
Main bearings
Big end bearings
Cam bearings
Pistons and barrells
Valves
Valve guides
seals
These are proberly the most common items.
the only way to learn is get a clunker engine and strip n rebuild it an see if you can make it run again, without spending too much money on it but
dont expect it to last too long
kombi_kid
Threads: 341
| posted on November 11th, 2003 at 07:09 PM |
the reason for this is exactly that i have 3 months off skool to do somethin i thought i would do somethin constructive plus for the next two years i
wont to build an industrial VW motor!
but me and my bro are gonna rebuild his 1916 as its leaking oil in the rear main!! so yer! thats my life story
rhys
KruizinKombi
A.k.a.: Col
Threads: 104
Mood: Indifferent
| posted on November 13th, 2003 at 04:27 PM |
Get yourself some appropriate measuring equipment (micrometers, inside guages, dial indicator, etc.) and read the manual!!!
Kruizin Kol
VWCOOL
Threads: 235
Mood: happy to help
| posted on November 13th, 2003 at 06:33 PM |
posted by kombi_kid
rhys
yeah, I was gunna mention using 94s to make it a 1916...
Pay your debts, CxxT
kombi_kid
Threads: 341
| posted on November 13th, 2003 at 06:44 PM |
ahahahahahahaha u'll never let up will you :cussing
i will one day
rhys
Grey 57
A.k.a.: Dean
Old Grey Cruiser
Threads: 355
Mood: (OoVoO) (OVO).
| posted on November 13th, 2003 at 09:06 PM |
Good one Dave Helpful as ever
Rhys, check the crank were the end float shins are. If they cut a groove thru the crank down into the area were the fly wheel dowels are located that
will cause a oil leak. When this happens the crank is junk.
Other wise as Dave said in his 2nd post. Valves rings and big end bearings for sure for sure. :thumb
vw54
| posted on November 13th, 2003 at 09:45 PM |
Rhys the most important item to check is the Crankcase and this must be inspected with a magnifying glass.
If the case is gone then so is yr motor no matter what else you replace you wont have a decent engine.
Unfortunatly case inspection comes with engine build experience, you can measure all the opening on a case but experience tells you when its STUFFED
kombi_kid
Threads: 341
| posted on November 14th, 2003 at 11:51 AM |
hey
when the motor was built by stan a few years ago the case was perfect but there has been some corrosion between the sump plate and the case.
checked out all the flywheel and rear main is fine!!!on inspection with engine running it looks like oil is coming out between the crankcase join
where it splits apart??? is there a seal or sumthin to stick in between there where re assembling it?
rhys
vw54
| posted on November 14th, 2003 at 05:55 PM |
Use Curall gasket goo.. non hardening
