[ Total Views: 1796 | Total Replies: 8 | Thread Id: 15955 ]
Author: Subject: Buggy Wiring Diagram Wanted
MemberAndy42
Threads: 47
Mood: 2.5t Subi Powered
posted on November 19th, 2003 at 09:36 PM
I need a basic wiring diagram for a manx or simmilar. No frills just the important stuff:)
MemberBrad
Threads: 332
Mood: Manx Buggy Building
posted on November 19th, 2003 at 11:24 PM
mmm
you should join the Manx Club then ... oh thats right you have :P:o
Brad
Meyers Manx Australia
MemberBrad
Threads: 332
posted on November 19th, 2003 at 11:26 PM
1
1
Brad
MemberBrad
Threads: 332
2
2
Brad
Memberhandycam
king of something
Threads: 61
posted on November 20th, 2003 at 04:54 PM
brad u r a legand now i have the digram i need and i dident have 2 ask :thumb and the off road secton grate thinking
MemberBrad
Threads: 332
posted on November 20th, 2003 at 07:12 PM
Cool
Glade I could help. I have them in bigger file sizes if you want them clearer as well.
Brad
Memberbugggy@hotmail.com
Threads: 1
Mood: pissed off
posted on May 9th, 2004 at 09:23 PM
Originally posted by Buggy Brad
1
where's the voltage reg in these pics? can u do with out?mmmmm
MemberBrad
Threads: 332
posted on May 9th, 2004 at 10:52 PM
on top of generator
Brad
posted on May 9th, 2004 at 11:27 PM
That is a good diagram Brad, it looks like it uses the same fuses as the beetles do... and VW switches..
I rewired My Sons girlfriends Baja 69 beetle and they wanted toggle switches in the dash, so thats what they have, no VW switches at all, apart from ignition & blinkers & horn....
I thought many buggies would use toggle switches Brad ... as You can get the rubber covers for them so they are water proof too..
I have a few small toggles with the rubber caps under My dash.. with some telltale small lamps in the dash...
so You know when the electric fuel pump is turned off...
Green light is On, and the engine can be started...
No green light.. No start...
Well thought out..
MemberBrad
Threads: 332
posted on May 9th, 2004 at 11:43 PM
no switch you mention is water proof, they all have the same weak spot which is the back of them, thsi makes then suck in a bauugy / baja.
I use VW switches as I have found them to be the best. I use kombi ones most of the time as they are easier to get
Brad
MemberMad Manx
A.k.a.: Travin C.
KombiKroozin
posted on May 12th, 2004 at 07:27 AM
You guys all rule:thumb:thumb:thumb
Its amazing I just logged on to ask this very same question
and here it is with all the answers I needed:)
http://users.tpg.com.au/travin/kombi/Komanxcab.jpg
- '71 Kombi (Died 24/11/05:sniffle: ) - '65 manx (smick) -'63 beetle (bent) -'73 Singlecab (new to the stable)
[ Queries: 40 ] [ PHP: 21.1% - SQL: 78.9% ]
