| [ Total Views: 466 | Total Replies: 5 | Thread Id: 17953 ] |
Adam_C
Threads: 164
Mood: could be lower
| posted on January 19th, 2004 at 02:00 PM |
spring return on 28pict carbie
the 28pictcarb has no spring return, how do i rig one up, can ne1 help me with it ?
Adam
Adzslick@iprimus.com.au
Andy
Andy's Adventures
Threads: 181
Mood: Happy Man
| posted on January 19th, 2004 at 05:35 PM |
From memory, the stock one is a simple coil spring.
Try the wreckers if your close to one, or many bolt places/hardware stores have a range of springs. Sure to have one close.
:thumb
Old Dubber
Threads: 25
Mood: great!
| posted on January 19th, 2004 at 05:49 PM |
Adam_C
Andy is correct. The early carbs had a simple coil spring approx 9mm dia 150mm long that fitted over the accel cable between the fan housing and the
butterfly lever.
You can make a bracket similar to the later carbs that will use the normal spring.
Adam_C
Threads: 164
| posted on January 19th, 2004 at 06:05 PM |
bracket? hmmmm how would i fo bout that, will investigate gettin another spring 4 it too
Adam
vw54
| posted on January 19th, 2004 at 06:34 PM |
Adam
Go and get a stock spring, clip, accelerator tube and spring retainer tube that goes through the fan housing or come and see me and i will find
one for you.
Adam_C
Threads: 164
| posted on January 19th, 2004 at 06:38 PM |
if you have one dave, ill get dad to swing past on his way home from work and grab it, he works in belmore, if it meand hours of searching under your
house in the parts depot, then ill save your knees and go visit lee at volkshaven.
and i owe you a few crownies for all the advice, ....... ill bring a case to valla hehe
Adam
vw54
| posted on January 19th, 2004 at 06:42 PM |
Yep i will have to DIG around and find all the right bits. Give me a few days n i will try n get it together.
Adam_C
Threads: 164
| posted on January 19th, 2004 at 07:01 PM |
ok sweet, pop me a post or u2u when ya have tha bits,
thanks
adz
Adam
