| [ Total Views: 475 | Total Replies: 1 | Thread Id: 18250 ] |
Softop
Threads: 19
Mood: My wife has enough moods for both of us!
| posted on January 29th, 2004 at 03:27 PM |
No Vacuum on distributor!
Would anyone know why the distributor on my '68 (with a 1300mtr) does not have a vacuum thingie on it? I was under the impression that anything
with a set of points had to have some sort of vacuum advance/retard system!:o
Roger.
If you drive fast enough you're past the accident before it happens !
Bizarre
| posted on January 29th, 2004 at 03:33 PM |
Because it will be a 009 distributor.
These are a very common replacement for the vac dizzy.
Not as good but ok.
Most hottie twin carbed motors use them cause it is hard to pick up a vac signal of a set of duals.
From there some people have missed the point and thought the 009 itself was a hottie add on.
You are better off with the correct vac distributor but the cost about twice a 009
Craig Torrens
A.k.a.: Craig Torrens
Threads: 347
| posted on January 29th, 2004 at 04:30 PM |
it has a mechanical advance using weights instead of the carbies vacuum. That's how it changes the timing via the engines revs.:thumb
Softop
Threads: 19
| posted on January 29th, 2004 at 05:10 PM |
009!! Bugger........ Being a "European convertible" they could at least have called it a 007! I'd have to agree with the
'hottie' label thought Blue, it's been above 30c here all week, just try touching the motor then
And thanks to both of you for the answer, and putting me out of my misery.
Roger.
