[ Total Views: 446 | Total Replies: 3 | Thread Id: 18366 ]
Author: Subject: Engine cuts out whilst driving
MemberKafer Lover
Threads: 71
Mood: Low
sad.gif posted on January 31st, 2004 at 07:48 PM
Anyone got any thoughts why the engine may just cut out whilst driving along?
It has happened 3 or 4 times over the last couple of weeks, while just driving along normally at 60km/hr.
It starts up again straight away with a turn of the ignition.
I'm going to give it a bit of a service tomorrow, but any thoughts would be appreciated.
posted on January 31st, 2004 at 07:57 PM
First guess is electrical
Now the hard part - where :jesus
I am guessing a wire is shorting or open circuiting somewhere.
Key switch
coil
condenser
Somewhere in the control circuit.
ie not lights etc.
Try idling the car and jiggle all wires in the key switch, ignition area. The positive to the coil. The negative of the coil to the dizzy
MemberKafer Lover
Threads: 71
Mood: Low
posted on January 31st, 2004 at 08:08 PM
Will try that, thanks for the suggestion.
Membersilver
Dangerous when poked
Threads: 162
Mood: In 2 Minds
posted on January 31st, 2004 at 11:30 PM
My Kombi did this then i found that the key switch was worn out and needed replacing
Keeping it real !
Membermatt111
Threads: 0
posted on February 6th, 2004 at 08:57 PM
The fuel exit nipple on the bottom of your fuel tank is almost blocked solid. Take it off and you will see what I mean. It happens to all VW's sooner or later.
Memberfish
Threads: 32
Mood: just cruisin
posted on February 7th, 2004 at 04:58 AM
could be the coil. does it get very hot ???
