[ Total Views: 920 | Total Replies: 8 | Thread Id: 1869 ]
Author: Subject: fitting electric windscreen washer
Super Moderatorkombi_kid
Good Kid too many projects
Threads: 341
posted on November 20th, 2002 at 03:52 PM
hey
what electric windscreen washers do people use and how do they fit them its for a kombi.
rhys
MemberAndy
Andy's Adventures
Threads: 181
Mood: Happy Man
posted on November 20th, 2002 at 04:12 PM
What I've done is to get the 12V pump out of an el-cheapo washer kit (most car parts places have them) and connect it onto the original water container. The pump simply connects into the line from the bottom of the original bottle feeding the washers. I also removed the valve for pressurising the bottle, and extended the tube up under the dash as a breather.
Then it was a simple matter if a power cable (make sure it's fused!) and a switch on the dash.
I'd also recommend replacing the tubes if they are original, as they are more than likely perished by now.
:cool:
posted on November 20th, 2002 at 09:29 PM
Good advice from Kombi kid about using the original washer bottle. I have electric washers on my bug. I fitted a micro switch in the wiper switch so that when you pull back on the wiper stalk to use the washers it operates the washers via the micro switch.
1302Steve
Member70AutoStik
Threads: 18
posted on November 20th, 2002 at 09:56 PM
Similar, but I just used the bottle and motor from a kit supposed to be for a holden - holds plenty of fluid, keeps the cops happy and, best of all, it's cheap!
Threads: 341
posted on November 21st, 2002 at 06:06 AM
thanks for the info guys!
rhys
posted on November 21st, 2002 at 07:29 AM
Rhys
Use the origional VW bottle and get an aftermarket pump there about $11.00 from most places.
If you carnt find one let me know.
MemberPat
Threads: 31
Mood: Radiant!!!
posted on November 21st, 2002 at 01:55 PM
My suggestion, put in the most powerful washer pump you can find, and install extra squirters to get pedestrians with. Heaps of fun.:P
Threads: 341
posted on November 21st, 2002 at 07:50 PM
hey thanks dave any brand names to make it easier?
rhys
posted on November 22nd, 2002 at 07:18 AM
rhys
Just go along to the local Coffs Auto one or Repco store they should have a catalogue listing several different styles available, pick one that has a mounting block so it will make fitting to your car easier.
Threads: 341
posted on November 22nd, 2002 at 03:32 PM
thanks dave!
rhys
MemberVWFOOL
Threads: 572
Mood: inspired yet?
posted on November 23rd, 2002 at 09:55 AM
hey reece
probably repeating wat others said but i fitted one of these pumps to my '59. remember the one i told u about that i had problems getting a blu slip for?
the motors r cheap and the job is not very difficult. i mounted the motor down behind the spare wheel in the beetle, im not sure wat the kombi is like though.
but anyway, its not hard to do at all and u can use ur original bottle no problems...
has anyone fitted one to an Oval, theres no squirters?:repuke
sam
One man's junk...
Threads: 341
posted on November 23rd, 2002 at 10:21 AM
i have a water pump as dad showed me (bought it for a fountain and never got made) its one from dick smith so i will try and make up a braket for it today! where about do u hook it into bottle?
rhys
Member70AutoStik
Threads: 18
posted on November 23rd, 2002 at 05:00 PM
pipe at bottom of bottle to tube to T-piece, to squirters. If you are using the original make sure you leave the vent hole open (where the tube came from the tyre.)
[ Queries: 40 ] [ PHP: 3.5% - SQL: 96.5% ]
