| [ Total Views: 574 | Total Replies: 3 | Thread Id: 18969 ] |
mountainbug
Threads: 34
Mood: allways wanting
| posted on February 14th, 2004 at 03:07 PM |
oil pump removal
just brought a heavy duty pump with filter, how's the easist way to remove old pump with out breaking the case? - need any special tools, any
ideas.....
John
Bizarre
| posted on February 14th, 2004 at 04:07 PM |
Hmmm..... "can" be done in car.
You need to get the pulley off.
BIG spanner.
then you need to get that bit of tin off.
Then the cover to the pump, and take out the drive gears.
You then get a special puller thing that hooks into the 2 holes and you do up the nut and it pulls the pump out.
Easy - :o
Ummm..... you "do" know what cam you have?
deep dish or not??
mountainbug
Threads: 34
| posted on February 14th, 2004 at 05:15 PM |
blue
motor is out of car, gears removed, not sure about cam, when you say deep dish, pls explain. know were i can get pully from....measured slot (depth)
that goes in cam, new one 10mm, old one 8mm. same thickness
thanks
70AutoStik
Threads: 18
| posted on February 15th, 2004 at 10:19 PM |
You'll need to have the later-style 3 bolt cam (or any performance cam) to use your new pump.
I would recommend buying/borrowing the special tool for this job. Don't try to pry it off with screwdrivers or the like - it _will_ end in tears.
mountainbug
Threads: 34
| posted on February 16th, 2004 at 10:19 AM |
can someone tell me the difference between the two?
mountainbug
Threads: 34
| posted on March 3rd, 2004 at 08:17 PM |
with that amount of information.... I'll be on to it.
