| [ Total Views: 517 | Total Replies: 2 | Thread Id: 19367 ] |
bigbruvabob
Threads: 43
Mood: grouse
| posted on February 22nd, 2004 at 01:18 PM |
first tune after rebuild
Am about to do a first tune on a totaly rebuilt 1600 and wondering if anything else i should do in addition to
-valve adjust
-oil change
-dwell,idle and timing
- any reason why i should not use castrol magnatec 10 w-40 oil? Cheers David
Bizarre
| posted on February 22nd, 2004 at 07:48 PM |
ummm... sounds abou right
Maybe pull the plugs just to check
When you do the oil make sure you take the plate off not just the plug. Just to look what is laying on the plate
TTFN
Barry
esevwbits
Threads: 143
Mood: alive!!
| posted on February 22nd, 2004 at 09:44 PM |
Plugs are good for 20,000k .. If your going to pull the plugs, why don't you do a compression test at the same time , just to see that all is how
it should be ... I usually take the oil relief plugs out and clean them so they don't stick.. as thats where junk will accumulate after a
rebuild..
[Edited on 22-2-2004 by esevwbits]
MickH
A.k.a.: Michael Hutchinson
Hairy Gutted Sloth
Threads: 29
| posted on February 22nd, 2004 at 09:52 PM |
I personally would not reccomend the Magnatec oil.....just my opinion though. I use GTX2 in all my engines and have tried Magnatec, Do a search on
oils in the search bar and read what other people use and why... Would be good to retorque the heads if you have the tools (bottom studs only)
tssnq.com.au
Peter Leonard
Volatile
Threads: 52
Mood: shiny
| posted on February 23rd, 2004 at 12:13 AM |
gtx 2 here.:thumb
timing tappets head torque oil strainer oilchange smile
let sleeping dubs lie
