| [ Total Views: 803 | Total Replies: 6 | Thread Id: 19594 ] |
kombikim
A.k.a.: Kim
disfunctionally capable
Threads: 84
Mood: always bleary
| posted on February 26th, 2004 at 10:07 PM |
kombi oil cooler/remote filter setup
finally no more getting too hot,
remote filter unit (Perma-cool)
removes oil filter from being blasted with hot air at the exit point of the air cooling system for cyl 3 & 4 AND the hot air coming down from
standard oil cooler
also gives a far larger exit hole for the hot air from these cylinders
very easy to change filter , & it is a VW Golf filter , considerably less than half the cost of a Kombi fliter & available everywhere,
Oil cooler is a high quality matrix type 11" X 8" (large) fitted horizontally & up out of harms way , air flows over both top &
bottom , & if need be (doubtful at this point) a scoop will be put at the REAR of it,
(negative pressure) air will get sucked over it, but dirt won't get forced in
and.. 6 metres of hose lines.
disadvantage over kombiluva's set up is that this does not at present have a thermostat, although it can be fitted
I am not too worried as I run very thin oil
(HPR 5) & have designed a sliding cover for the cooler to fit in winter
I am grateful to Richard at V-force for the suggestion of how to set up, & supply of the bits, I never would have thought of fitting the cooler
horizontal, but it sure does work
Please, I need drivers side window regulator (winder mechanism) for my '54
modulus
A.k.a.: Peter Hill
Mood: modular
| posted on February 26th, 2004 at 10:18 PM |
One very neat looking job!
There's still plenty of warm weather to come this year.
kombikim
A.k.a.: Kim
Threads: 84
Mood: always bleary
| posted on February 26th, 2004 at 10:29 PM |
funny actually I fitted the oil cooler on Saturday in 40 degree heat & just had time to take it on a worst conditions I could find drive, then a
col change came through & then rain & still rain:jesus
forgot to mention that it now runs 15 degrees F cooler No holes drilled anywhere either , brackets look a bit crappy but they were fabricated in a
hurry
[Edited on 26-2-2004 by kombikim]
Craig Torrens
A.k.a.: Craig Torrens
Threads: 347
how much for the cooler ?
kombikim
A.k.a.: Kim
Threads: 84
Mood: always bleary
| posted on February 26th, 2004 at 10:36 PM |
I think that was $120, I bought a lot of bits, American Auto parts was $126 for one only 3" X 8" & other places were mostly over $200
for anything useful
Andy
Andy's Adventures
Threads: 181
Mood: Happy Man
| posted on February 26th, 2004 at 10:55 PM |
Sweet
KOM123
Smiling Assassin
Threads: 121
Mood: Always cheery!
| posted on February 27th, 2004 at 12:02 AM |
Excellent work Kim :thumb
mnsKmobi
Threads: 27
| posted on February 27th, 2004 at 07:59 AM |
Kim,
Is that your heater pipe wrapped in something in the third photo? If so, what is it and does it make a difference?
kombikim
A.k.a.: Kim
Threads: 84
Mood: always bleary
| posted on February 27th, 2004 at 08:13 AM |
it is wrapped in some sort of plastic , with nominal amount of insulation & has been there from new (75 microbus deluxe) I can't tell you
what sort of difference it makes because I have not yet got the heaters working
