[ Total Views: 581 | Total Replies: 5 | Thread Id: 19654 ]
Author: Subject: strange engine #
MemberMad Manx
A.k.a.: Travin C.
KombiKroozin
posted on March 1st, 2004 at 09:49 AM
strange engine #
I have an engine at home with an engine number I cant identify- can anyone shed some light?
its an upright dual port. generator not alt. and was removed from a 1965 beetle.
the numbers under the gen stand are: 5025538
they are not stamped evenly and are smaller in size to other #'s on motors i have. Also there has not been any grinding or sanding of the block so I guess they are the original numbers as such.
http://users.tpg.com.au/travin/kombi/Komanxcab.jpg
- '71 Kombi (Died 24/11/05:sniffle: ) - '65 manx (smick) -'63 beetle (bent) -'73 Singlecab (new to the stable)
MemberMad Manx
A.k.a.: Travin C.
KombiKroozin
posted on March 1st, 2004 at 09:50 AM
P.S. there are no letters before the numbers.
MemberMikeM
Buggy Head
Threads: 71
Mood: :duh
posted on March 1st, 2004 at 09:56 AM
It might be a type 3 engine, in which case the real number will be under the fan shroud next the oil cooler outlet.
A previous owner may have copied only part of the number to the Type 1 location under the generator stand. Or thought it didn't have one so made one up :o
Best of luck
MemberPurple Martin
A.k.a.: Martin
Threads: 141
Mood: warm & fuzzy
posted on March 1st, 2004 at 11:19 AM
I think I remember hearing somewhere that if you build your own new engine from scratch you get allocated a number by the relevant road authority. Maybe that's what happened with your engine.
1959 red & white Beetle
1975 Kombi camper
Memberbaybuscamperkid
Threads: 335
Mood: transported
posted on March 1st, 2004 at 07:48 PM
according to the book infornt of me the only engines that came with a 5 at the front were the 1961 1200s
Member70AutoStik
Threads: 18
posted on March 1st, 2004 at 08:51 PM
Yes, had a number allocated by the relevant authority and stamped on by the mechanic when I had a rebuild with a new case. And a 1600 DP is certainly not the original engine for your car
Easy enough to check, does it match the number on the rego papers?
MemberMad Manx
A.k.a.: Travin C.
KombiKroozin
posted on March 2nd, 2004 at 08:42 AM
yeah the same numbers are on the rego papers- the previous owner told me it was a 1775cc but nothing more. I was just curious as to what case it was originally and a little worried that I may have probs when it comes time to re-register it again.... but I guess if the numbers are on the old rego slips then it must be ligit:D
MemberDesert Bug
Threads: 72
Mood: NOW VERY HOT AND HUMID!!!
posted on March 2nd, 2004 at 11:52 PM
Looks like it may be a Type 3 1600 converted to upright fan to suit the Beetle and stamped with the 1200 engine number of the previous motor to save a visit to the Rego Branch.
