| [ Total Views: 596 | Total Replies: 12 | Thread Id: 19699 ] |
Secoh
Threads: 97
Mood: Rarin' to
| posted on March 1st, 2004 at 08:08 PM |
6V starter...how do you identify if it is one?
I have a starter that came with a box of crap with my '68 baja.
I dont know what year it's from, but it looks ancient. its huge, and has screw on plates on the solenoid.
Someone wanted a 6V starter and I don't want to get his hopes up because I have NFI what this one is...
how do you tell without fitting it up and trying it?
If it aint broke,
Make it go faster!!
1303Steve
| posted on March 1st, 2004 at 09:00 PM |
The voltage is written on them and the 6 volters have a larger spigot bearing size.
1302Steve
68AutoBug
posted on March 1st, 2004 at 09:27 PM |
6 volt versus 12 volt starter Motors...
The 6 volt starter has a different number of teeth to mesh with the 6 volt ring gear. 6v & 12v have different number of teeth on the ring
gear. I can count the teeth on a 12 volt starter motor tomorrow, but they normally have the voltage stamped on them... The mounting holes for 6v &
12v are the same , as far as I know, back to around 1961... not sure on ovals etc...
Lee Noonan
Secoh
Threads: 97
Mood: Rarin' to
| posted on March 2nd, 2004 at 07:46 AM |
thanks guys. if you could count the teeth thatd be great. there is no Voltage numbering anywhere on it.
If it aint broke,
Make it go faster!!
Secoh
Threads: 97
Mood: Rarin' to
| posted on March 4th, 2004 at 06:31 AM |
well I took some pics of it, can anyone confirm what it is?
If it aint broke,
Make it go faster!!
lugnuts
A.k.a.: Mike
Threads: 88
Mood: semi-retiring
| posted on March 4th, 2004 at 04:31 PM |
That looks a hella lot like my 6v starter but im usually wrong so that would make it a 12v  |
68AutoBug
| posted on March 5th, 2004 at 09:10 AM |
12 volts starter has 9 teeth....
Well, it IS definately, dirty & crappy looking... and OLD looking..
A 12 volt starter motor has 9 TEETH on the pinion....
I just counted them... not sure about a 6v
should be more or less - not the same though...
Lee Noonan
[Edited on 4-3-2004 by 68AutoBug]
68AutoBug
| posted on March 5th, 2004 at 09:23 AM |
and it doesn't say whether its 6v or 12 volt on the strater motor...
It wouldn't have taken much to stamp a couple of extra numbers....
Lee Noonan
68AutoBug
| posted on March 5th, 2004 at 09:37 AM |
from Chilton's VW Manual..
36HP starter : Bosch EED 0.4/6L/4
40 HP starter : Bosch EEF 0.5/6L/1
40 HP type 2 : VW 113 911 021 B
these are 6 volt starter numbers.
this may be of some help..
Lee Noonan
[Edited on 5-3-2004 by 68AutoBug]
sgetty
Threads: 117
Mood: yep
| posted on March 5th, 2004 at 11:54 AM |
off the subject but on the same line
what was the first year the 12 volt came out?
Secoh
Threads: 97
Mood: Rarin' to
| posted on March 5th, 2004 at 02:16 PM |
thanks lee. my one there has 9 teeth so i guess that makes it a 12V.
anyone want it? otherwise the OTTO is gonna eat it.
If it aint broke,
Make it go faster!!
68AutoBug
posted on March 5th, 2004 at 10:37 PM |
12 volts arrived in Australia in 1968 ***
The first 12 Volt Beetles sold in Australia were the New Updated 1968 Model.... In the UK, they were still selling 6v 1200cc beetles in
1968...
Most 6 volt starter motors would have been thrown away many years ago...
Lee Noonan
Che Castro
ankle straps
Threads: 79
Mood: (( }:-{D]
| posted on March 7th, 2004 at 02:37 PM |
6v starters have the solenoid terminal posts at 45 deg angles. the 12v ones go straight up
Jon
twoguns
simply aircooled
Threads: 226
Mood: simply cruizin'
| posted on March 7th, 2004 at 05:26 PM |
secoh. that looks like a 6v starter to me. i was told you could tell the difference, as a 6v has taht plate on the terminal side. and 12v dont. here
is a pic of two 6v. the top one is from pre 66.
then a 12v at the bottom.
Simply Cruzin'...
twoguns
simply aircooled
Threads: 226
| posted on March 7th, 2004 at 05:28 PM |
and i think a shaft on the 12v is thinner.
Simply Cruzin'...
