[ Total Views: 485 | Total Replies: 10 | Thread Id: 19773 ]
Author: Subject: door pops open on bumps on 60's bug
Membervdbleu2002
Threads: 40
posted on March 3rd, 2004 at 05:17 PM
Is there an adjustment or worn parts to be replaced to rectify this. Any advise would be greatly appreciated.
Membernicko
Threads: 77
Mood: Tired
posted on March 3rd, 2004 at 05:36 PM
doors opening
You should check the hinge pins to see if they are loose. Open the door and grab the outside edge and see if it rocks up and down. If it does they may need replacing. This was the problem with my old 66 bug. It also did not help that the car was lowered which made the bumps a lot harder than a stock suspension would. You should get some one who knows what they are doing to check and change pins if neccessary
Nicko
MemberOasis
Going alone...
Threads: 77
Mood: Deep
posted on March 3rd, 2004 at 05:49 PM
Mine used to pop open all the time. I thought they all did to a degree? Worn striker plate I think, or the pins as nicko suggested
Memberpod
A.k.a.: paul mrvw061
Mood: could be better
posted on March 3rd, 2004 at 05:51 PM
I`d say most likely worn striker plate or badly adjusted
check wbsite for location
All Welcome
http://www.flatfour.org/
MemberVWFOOL
Threads: 572
Mood: inspired yet?
posted on March 3rd, 2004 at 06:28 PM
if u hav rust in the a pillars down the bottom could this affect the doors shutting properly. ive seen the doors continue to pop open even after striker plates hav been replaced wen there is rust in the channels. wat do u think?
One man's junk...
MemberBettyBoop
Threads: 35
Mood: Boop-Oop-a-Doop
posted on March 3rd, 2004 at 07:16 PM
ROFL!!!!
All i can say is... U2U a guy on forum here called Skyhawk or Liam... he'll tell ya ALL BOUT IT ... he's bin gettin his bug "grimace" to try n stop doin that exact same thing...
ciao
Kat
Member555bug
WRX Bug Boy
Threads: 79
Theme: UltimaBB Vintage
Mood: turbo charged
posted on March 3rd, 2004 at 08:19 PM
replace the rubber on the front beam-to-body. When worne they also contribute to this.
Memberjnr356
Threads: 33
Mood: casual
posted on March 3rd, 2004 at 09:27 PM
usually the striker plate is worn,but have also had dodgy door lock mechanisms do this as well.
http://s23.postimg.org/vl55hvvev/flipinthebirdcopy3.jpg
MemberByronBug
Threads: 150
Mood: Bent
posted on March 3rd, 2004 at 09:40 PM
:sandrine
Most people have suggested it may be your striker plates...so check them first.
I had the same problem a little while ago with my drivers side door....
These get worn out & is the most common problem, so replace them first, then if this is still happening, follow everyone else's suggestions
Judy
59 Microbus Kombi (MERCY)
64 Microbus Kombi (CHANNON)
MemberCanni.
Threads: 29
posted on March 4th, 2004 at 05:38 PM
Mine started popping open once I had new door rubber seals put on :( not only do they pop open on bumps but also sometimes when turning....hehehe and the best...close one door and the other one pops open :D
Heidi - 1960 White Beetle
'65 Kiwi Ghia
MemberChe Castro
ankle straps
Threads: 79
Mood: (( }:-{D]
posted on March 4th, 2004 at 10:26 PM
yeah my 63 does this. Its pretty common on the older bugs.
Mine only happens on the drivers side, i replaced the striker plate, although it still opens, it has been adjusted to the manual spec. The latch bit on the actual door wears out too. My hinges are pretty old too.
the design is pretty crap compared to the late bug design, the late bug design is like a modern car, it cant accidentally bust open to the safety catch
Jon
MemberOasis
Going alone...
Threads: 77
Mood: Deep
posted on March 4th, 2004 at 11:53 PM
Out of curiosity, can you put later model doors on older bugs? or even just the plates?
MemberSky
Threads: 43
posted on March 28th, 2004 at 10:32 PM
Hihi Finally I see a post I have a bit on info on :)
Could be many things, With grimace it was that there was a repair and full of bog, you would drive along or go around corners and bang the door flew open, job was about $300 to fix and now there is welded metal, doors now close.
Try opening the door and lifting it up, look at the hinges see if there is play there :)
