[ Total Views: 728 | Total Replies: 7 | Thread Id: 19808 ]
Author: Subject: backfiring,not idling,running like a dog when hot????
Super Moderatorkombi_kid
Good Kid too many projects
Threads: 341
rsvd_idea.gif posted on March 4th, 2004 at 09:32 AM
hey people
this is all happening to our type 3 1500 motor.
it struggles to idle and when giving it a boot full in 4th and slowning down u get a big bang and then when it gets hot it struggles to even go!!
its running the twin 1500 carbies which have been rebuilt.
any help ????
rhys
MemberOld Dubber
Threads: 25
Mood: great!
posted on March 4th, 2004 at 11:44 AM
Sounds like lean mixture.
Look for vacuum leaks.
Grahame
visit my club site at www.vwdcqinc.org.au
MembermnsKmobi
Threads: 27
posted on March 4th, 2004 at 12:11 PM
Is the timing right?
Memberkombikim
A.k.a.: Kim
disfunctionally capable
Threads: 84
Mood: always bleary
posted on March 4th, 2004 at 12:15 PM
I agree with MNS Kombi
this is usually a timing /distributor guts issue, the carbies are the last thing that should be touched unless something is visually obvious
MemberRobo
Threads: 120
Mood: Oval madness
posted on March 4th, 2004 at 04:18 PM
Dont know much about Type 3's but in a Kombi there is a balance tube between the carbs, sometimes the rubber elbow's come off the pipe creating a vacumm leak, the symtoms are the same as you mentioned. might be worth a look if there is a similar balance tube in your car it could be the problem.
Rob..:cool:
Boxer Power
Memberrobnjo
Threads: 254
Mood: its tricky tricky tricky
posted on March 4th, 2004 at 08:46 PM
sounds like dissy,if you havn't, why not put a NEW 009 in it ,their cheap enough.
Threads: 341
posted on March 4th, 2004 at 09:02 PM
it has a 009 in it we will put the original back in!!!
we have blocked off the balance tubes should we unblock then and stick in the balance tube??
rhys
Member70AutoStik
Threads: 18
posted on March 5th, 2004 at 08:18 PM
That might help a heck of a lot! Without the balance tube the poor little 34picts will be suffering badly from the reversion pulses.
Memberkarmannghia60
Karmann Ghia Sucker
Threads: 388
posted on March 6th, 2004 at 07:37 AM
Could it be a bad tension lead?
Threads: 341
posted on March 6th, 2004 at 10:55 AM
fiddled around with the leads and it has become alot better!!! it is know not idling and backfiring have got rid of it running like a dog!!!
rhys
