| [ Total Views: 552 | Total Replies: 6 | Thread Id: 19949 ] |
AdrianH
Threads: 20
Mood: rebuilding again
| posted on March 7th, 2004 at 09:46 AM |
Hi rev miss
Ive been chasing it for a while, any suggestions would be appreciated.
On the ignition side Im running a 009 disi with compufire, mallory coil and a hyfire VIal (same as MSD 6al). Plug wires are new, wiring is good, runs
fine till about 500 rpm short of the limiter (7000) then develops a miss - If I keep pushing the rev limiter cuts in.
On the fuel side, electric pump, holley reg, dellortos. I had a tank vacuum problem that I fixed (no vent on tank ). I thought maybe it was a pump
problem and leaning out.
I thought I might be floating valves, springs are bugpack duals, and only have 900 miles on them. I am going to change them anyway just in case.
Any ideas ???
lugnuts
A.k.a.: Mike
Threads: 88
Mood: semi-retiring
| posted on March 7th, 2004 at 09:50 AM |
How big are the valves dude  |
AdrianH
Threads: 20
| posted on March 7th, 2004 at 01:00 PM |
42 inlet 37.5 exhaust
Peter Leonard
Volatile
Threads: 52
Mood: shiny
| posted on March 8th, 2004 at 05:17 PM |
the sound of valve float is pretty definate...
sure it's still making power at 7000? take it to a dyno and add the figures to the dyno gang bang
let sleeping dubs lie
AdrianH
Threads: 20
| posted on March 8th, 2004 at 05:28 PM |
You are right its not valve float, Im going to play around with jets. I kind of have to beat it up to stay in the groove with my gearbox.
3.88:1 r and p and stock ratios, it takes a bit of convincing to get to the top of third...
If there was a dyno worth going to within 100 miles of here Id be there.
[Edited on 8-3-2004 by AdrianH]
modulus
A.k.a.: Peter Hill
Mood: modular
| posted on March 8th, 2004 at 05:54 PM |
It's kind of hard for us to guess where 'here' is since you haven't filled out your location. Ettamogah? Turkistan? Mongolia?
hth
Peter Leonard
Volatile
Threads: 52
Mood: shiny
| posted on March 8th, 2004 at 05:58 PM |
5 to one one Uzbekhistanislovenia
lugnuts
A.k.a.: Mike
Threads: 88
Mood: semi-retiring
| posted on March 8th, 2004 at 06:12 PM |
Kiwi :thumb |
AdrianH
Threads: 20
| posted on March 10th, 2004 at 05:32 AM |
Good guess - Kiwi small rural town, bunch of V8 guys locally, gave them a bit of a scare at the local car clubs 1/4 mile sprints (in the pouring rain)
ran a 15.57 with no traction in first, yet to get to a real strip.
