[ Total Views: 707 | Total Replies: -1 | Thread Id: 2033 ]
Author: Subject: Seal between Gear Box and Pan on an Oval
MemberGrey 57
A.k.a.: Dean
Old Grey Cruiser
Threads: 355
Mood: (OoVoO) (OVO).
posted on November 27th, 2002 at 10:59 PM
Is there supposed to be a rubber seal on or around the area where the selector shaft connects through the pan tunnel to the shifter rod.
1200 Tunnel case box in an Oval.
Would this seal missing or torn make the car really noisy.
I either gotta get a quieter car or a louder radio.:jesus
posted on November 28th, 2002 at 06:27 AM
yeah Ovals only relied on the stock flat type seal, the later 1200s used an extra round section placed onto the top of the stock flat seal.
the round section was about 15mm dia and was approx 30 or 40 mm long, and layed around the gear selector opening you might be able to get some from clark rubber ??
you can add this to your oval as an extra if you want.
It does not seal too good due to no body bolts in this area.
If you have already bolted this down then get some mastick goo black stuff non accidick and use that to seal it up.
to reduce the noise you could also put some felt insulation under the rear seat and also behind it up the fire wall section:bounce
MemberGrey 57
A.k.a.: Dean
Old Grey Cruiser
Threads: 355
posted on November 28th, 2002 at 11:09 AM
Thanks Dave, you wouldn't have a pic of what this is supposed to look like.
Can you still buy these seals.
Dean
posted on November 28th, 2002 at 11:47 AM
now i can draw it and FAX it to u or post if you like
send me yr FAX number
