[ Total Views: 506 | Total Replies: 7 | Thread Id: 20741 ]
Author: Subject: blow by box how to do ?
Memberseagull
Threads: 752
posted on March 26th, 2004 at 09:22 PM
I see some of the bigger motors have these fitted how does this box work and does any one have one they dont need ? thanks seagull
Memberlugnuts
A.k.a.: Mike
Threads: 88
Mood: semi-retiring
posted on March 27th, 2004 at 05:12 AM
Well according to god breather boxes are to separate the oil from the air/oil mist thats in your case and to let your case breathe by venting via lines to your carbs and to then return the oil to the case on deceleration,and i have no idea what i just said so direct all enquiries directly to GOD.:)
Memberseagull
Threads: 752
sad.gif posted on March 27th, 2004 at 09:50 PM
Please god reply to me
:jesus
MemberBrad
Threads: 332
Mood: Manx Buggy Building
posted on March 27th, 2004 at 11:33 PM
boxs
They basically act as an air filter for your case / tappet covers and reduce crank case presure thus reducing blow by. I use a K & N filter on top of a funnel. This allow breathing when under pressure and when not it just runs back into the case.
You can buy breather boxes for like $50 which are alloy case filled with foam .
Brad
Meyers Manx Australia
MemberBrad
Threads: 332
posted on March 27th, 2004 at 11:34 PM
oops forgot to say I am not god, the above is just my opinion :party
Brad
Memberseagull
Threads: 752
posted on March 28th, 2004 at 12:17 AM
Thanks Brad where can i puchase
a new or s/hand unit ( or I will swap for a fuel filter like the one I am sending you )
MemberBiX
Threads: 154
posted on March 28th, 2004 at 04:56 PM
you can make your own. Got one welded up at an exhaust shop, bought the fittings I needed and then the hose out it all together. Box cost $30 to make up plus hose plus fittings
Go hard or go home!!!!
MemberMikeM
Buggy Head
Threads: 71
Mood: :duh
posted on March 28th, 2004 at 08:57 PM
http://www.mickmotors.com.au
Mickmotors have a kit, about $60 or so. I bought it for my engine and it has all fittings etc. I would replace the hose that comes with the kit but the good hose is about $3 from a hose supplier.
MemberBrad
Threads: 332
posted on March 29th, 2004 at 02:37 PM
mmm
I have one of these in the shed, it is what Mike is talking about.
You have U2U :>
Oh the stuff in the pic is the kit BUT the Alloy Filler cap is not part of that, these are sold on their own.
[Edited on 29-3-2004 by Buggy Brad]
Brad
Memberkombikim
A.k.a.: Kim
disfunctionally capable
Threads: 84
Mood: always bleary
posted on March 29th, 2004 at 04:24 PM
I thought the blowby box was designed to fill engine bay & cabin with a fine blue haze & asphixiating fumes:jesus oh well, back to the drawing board
