| [ Total Views: 584 | Total Replies: 1 | Thread Id: 21000 ] |
kombi_76er
Threads: 21
Mood: kombi mad
| posted on April 2nd, 2004 at 06:17 PM |
kombi problems with timing or sumthin like that .. plz help
well this is the prob.
the other day i was driving to work n my kombi just had a srious drop in power and could not hold in 3rd gear so i drove to work in 2nd (lucky i only
work up the road) so i came home n readjusted the timing with a timing light and set it bak to 8 degrees it was sitting on about 20degrees (way to
high). after that it was fine and ran for about 3 day no probs then it done it again so this time i went out n bought new points and a new condensor
and set everything right. and now its continues to have the same prob. Wat the hell is wrong with it. Is it electrics or not, or could it be something
to do with fuel????
thanx guys
tassupervee
A.k.a.: Knob Jockey
That really hurts doesnt it!
Threads: 25
Mood: Moody!
| posted on April 2nd, 2004 at 06:54 PM |
WTF?
If the problem is the same with the ignition timing advanced right up then what has fuel got to do with it??????
I suggest you check that the securing bolt for the distributor clamp plate and the catual clamp itself is actually "clamping" the distributor
firmly.
Timing dont advance itself up to buggery unless the dizzy is allowed to rotate one way or other or the points magically open up.
Logic dictates that the dizzy would tend to retard the timing if it were loose but stranger things happen.
Try that dude
L8tr
E
Im not a complete idiot, quite a few parts are missing....
MickH
A.k.a.: Michael Hutchinson
Hairy Gutted Sloth
Threads: 29
| posted on April 2nd, 2004 at 09:32 PM |
Also check the dizzy is advancing etc and not "sticking" What kind of Distributor are you using??
tssnq.com.au
kombi_76er
Threads: 21
Mood: kombi mad
| posted on April 3rd, 2004 at 10:08 AM |
ummmm dunno will check out 2day but thanx guys ill have a fiddle.
