[ Total Views: 978 | Total Replies: 22 | Thread Id: 21078 ]
Author: Subject: splitty wheel arches
Memberrobnjo
Threads: 254
Mood: its tricky tricky tricky
posted on April 4th, 2004 at 04:54 PM
my wheel arches are non-existant(been cut out...??)
so what are my options? will any kombi wheel arch fit?
what year/s can I use?
I'm not going "showroom" but would like it to look normal.
please point me in the right direction.
Rob
[Edited on 14-4-2004 by robnjo]
Memberbaybuscamperkid
Threads: 335
Mood: transported
posted on April 4th, 2004 at 06:29 PM
you could weld up bay ones, but it wouldnt look correct, as they stick out a bit, wich the split ones do not, so really you should get split ones.
Member57kombi
Hannover Elder
Threads: 181
posted on April 5th, 2004 at 07:59 PM
Schofields in the U. K. do them, check out any copy of volksworld.
Dave
Super Administratorhelbus
A.k.a.: Pete S
Threads: 312
Mood: In the thinking chair
posted on April 5th, 2004 at 10:07 PM
Ring some sheet metal places and ask if you bring in a profile of the wheelarch, if they could make it for you? You might be surprised.
Memberrobnjo
Threads: 254
posted on April 6th, 2004 at 07:15 PM
thanks hellbus and guys,a profile of a splitty arch? not sure what you mean.
should I take a pic of the real thing or ?
A.k.a.: Pete S
Threads: 312
posted on April 6th, 2004 at 11:20 PM
A profile is when you get another bit of sheetmetal or masonite, and shape it so it sits side on to the wheelarch and has the shape cut into it.
This will give them a pattern to go by.
You could make another pattern/ profile of the whole wheel arch also.
This will be more difficult of course if you cannot get a splitty wheel arch to copy.
Memberrobnjo
Threads: 254
posted on April 7th, 2004 at 07:49 AM
thanks hellbus,
so it would be no good if I find an early bay and cut the arches out to use?
Memberrobnjo
Threads: 254
posted on April 14th, 2004 at 07:58 PM
this is them....so it would be a no go on early bay ones?
Member57kombi
Hannover Elder
Threads: 181
posted on April 14th, 2004 at 10:22 PM
I am not too sure but I think early bay ones were very close to the later splitty ones.
Dave
Membersgetty
Threads: 117
Mood: yep
posted on April 19th, 2004 at 03:31 PM
mmmmmmm they look simlar
[Edited on 19-4-2004 by sgetty]
Membersgetty
Threads: 117
Mood: yep
posted on April 19th, 2004 at 03:33 PM
splitt
Memberrobnjo
Threads: 254
posted on April 23rd, 2004 at 07:38 AM
thanks I'll go lookin' for some ......lock up your busses:thumb
Memberrobnjo
Threads: 254
posted on May 10th, 2004 at 08:35 AM
So has anybody got any they'd cut out of an old bus or early bay and sell to me?
MemberHerbie
53 Bugs are not nearly enough
Threads: 51
Mood: Nihil curo de ista tua stulta superstitione.Utinam logica falsa tuam philos
posted on May 10th, 2004 at 08:57 AM
Rob, when I was in a similar position with my old 67 Panel, I went to see Alec Brown, and we sourced them, You can come over and have a look at my 64 Kombie if you like, as it would have the same rear guards you are seeking and this way you have a better Idea of what you are after.
Cheers Tony
62 Ragtop Herbie with a little extra oomph.
Membersilver
Dangerous when poked
Threads: 162
Mood: In 2 Minds
posted on May 10th, 2004 at 10:08 PM
All these bit's available new from Bus Boy's
Keeping it real !
Memberrobnjo
Threads: 254
posted on May 11th, 2004 at 08:21 PM
thanks Silver......who's the "bus boys"?
hey Tony I'll call you......kool
Membersilver
Threads: 162
Mood: In 2 Minds
posted on May 11th, 2004 at 10:31 PM
Here Tis'
Keeping it real !
Memberrobnjo
Threads: 254
posted on May 16th, 2004 at 06:34 PM
thanks silver :cool:
Memberrobnjo
Threads: 254
posted on May 20th, 2004 at 07:00 PM
hey Silver,have you got stuff off these guys before?....like is it easy enough get the stuff in?
Membersplittychick
SplittyDelicious
Mood: Stoked to be cruisen!
posted on June 28th, 2004 at 10:35 AM
Heh Rob.........just wondering if you've had any luck with the wheel arches as i need some too.:o
Membersplittychick
SplittyDelicious
posted on June 28th, 2004 at 04:17 PM
Has anyone found any wheel arches in Oz that aren't on a donor bus????
Looks like i might have to order from Schofields!!
Memberbusnut
posted on June 28th, 2004 at 10:34 PM
if you can get the vw made item i would definetly recomend it, I bought his rear arches once and never used them because they were really s**t . the profile was similar but not the same and the finish of the moulding was rough and would of required much bogging to smooth them out.
Memberbusnut
Memberbusnut
Memberjnr356
Threads: 33
Mood: casual
posted on June 28th, 2004 at 10:49 PM
for sale on the samba at the moment
http://s23.postimg.org/vl55hvvev/flipinthebirdcopy3.jpg
[ Queries: 40 ] [ PHP: 19.0% - SQL: 81.0% ]
