| [ Total Views: 709 | Total Replies: 12 | Thread Id: 21433 ] |
baybuscamperkid
Threads: 335
Mood: transported
posted on April 11th, 2004 at 08:37 PM |
custom aircon in bus thoughts/questions
ok, i am awaiting a flywheel to be made before i go ahead and fit my ea81 eingine to my kombi, so while i wait i thought i might have a play around
with fitting the ariconditioning from the subaru. am after your opinions on whether or not my setup is going to work successfully;
i have placed the box that was under the dash of the subaru (the box houses the radiator bit that cools the air) and placed it where my battery should
sit on the drivers side of the bus, i am running a funnel up the vent on that side to provide fresh air to the unit, then running the cooled air from
the other side of the box down and into the old heater tubes then up through the standard airflow vents (maybe with a booster fan along the way). the
radiator for the aircon is hanging on its side on the opening where the rear hatch once was so as to minimise blocking the airflow for the real
radiator.
are there any problems with this system? anything that could be improved?
Ryan
[Edited on 14-4-2004 by baybuscamperkid]
baybuscamperkid
Threads: 335
Mood: transported
| posted on April 12th, 2004 at 08:39 PM |
anybody? will post some pics when i remember.
baybuscamperkid
Threads: 335
Mood: transported
| posted on April 14th, 2004 at 03:07 PM |
baybuscamperkid
Threads: 335
Mood: transported
| posted on April 14th, 2004 at 05:16 PM |
the unit in the engine bay
| Error |
baybuscamperkid
Threads: 335
Mood: transported
| posted on April 14th, 2004 at 05:17 PM |
aircon radiator thingy hanging
| Error |
11CAB
If ya got it....Baja it
Threads: 321
Mood: Beach'n
| posted on April 16th, 2004 at 08:34 PM |
Hate to burst your bubble.........but the evaporator that you have mounted where the battery should be needs to be inside the kombi, not in the engine
bay......the idea is that the evaporator transfers heat from inside the car to the gas in the lines which is then transfered to the condensor outside
the car where the heat is given off.
Graham
65 Meyers Manx
68 Country Buggy (KO 367)
68 Country Buggy (KO 669)
68 Country Buggy (KO 789)
68 Country Buggy (KO 815)
68 Baja Bug
76 Baja Kombi Twincab
KruizinKombi
A.k.a.: Col
Threads: 104
Mood: Indifferent
| posted on April 19th, 2004 at 11:49 AM |
I think Graham is right. Even though you've attached the Evaporator to the old heater tubes, you're going to pick up heat from the uninsulated tubes
running under the car, and it needs to suck air from inside the car, rather than the external vents, or on a 45 degree day it will be sucking 45
degree air all the time, rather than the precooled air from inside the bus.
I'd suggest mounting the evaporator under the rear seat instead. It's still close to the condensor and compressor, but will suck air from inside the
bus and pump it straight out again, without worrying about all that ducting.
Kruizin Kol
baybuscamperkid
Threads: 335
Mood: transported
| posted on April 19th, 2004 at 08:36 PM |
ok, but where should i run the pipes in? through the floor? i have a bit of cupboard space where it may be able to go as well, just hadn't realised
the way they worked. thanks for the info. if i suck the air from under the rear seat (will be a tight fit as water tank is down there), should i run
the air upto the front? cos if i had the outlet next to the inlet only a limited amount of air would be getting very cold.
KruizinKombi
A.k.a.: Col
Threads: 104
Mood: Indifferent
| posted on April 21st, 2004 at 09:08 AM |
Yes, you are right.
I wouldn't stress too much about it though, a shortish pipe would probably suffice. The pressure of the fan blowing the air out will create currents
of air movement anyway.....
Kruizin Kol
baybuscamperkid
Threads: 335
Mood: transported
| posted on April 21st, 2004 at 07:04 PM |
thanks. any chance of any pics of how you installed the central locking Col?
baybuscamperkid
Threads: 335
Mood: transported
| posted on April 21st, 2004 at 08:19 PM |
just another throught... since i currently have the plumbing in pieces, could i fit another type of cooler unit (i have in mind a 'head unit' of a
60s Val that i saw, big and flat and lots of chrome)? i presume they all run the same way and use the same sort of pipes for the gas? would a 10+yr
older unit have much worse cooling effect (most of the cooling effect would be due to the rest of the unit, wouldnt it?)?
Brad
Threads: 332
Mood: Manx Buggy Building
| posted on April 21st, 2004 at 08:43 PM |
mmm I think you need to do some research into the way that the A/C needs to be setup.
Basically yyou need to get the "head unit" is evaporator inside the bus and as close to the area you wish to cool. An evaporator is like a reveresed
radiator. Basically when you turn on the compressor it becomes cool and teh air blows over it. Ducting cool are from the rear of your kombi is not a
good idea as it will be hot and without pressure by the time it hits the front, unless you add booster fans like the VW heater.
I would mount your condensor under the bus with a thermo on it and the evaporator in the front under the dash. Then it will work well.
The early 70's head units you talk about will work fine with the new gas once they are services and have new orings.
baybuscamperkid
Threads: 335
Mood: transported
| posted on April 21st, 2004 at 10:17 PM |
ok. the current setup has been upgraded to suit the new gas (was done about 12 months ago). what i am considering is running the rather large
condensor at the rear of the bus (behind the radiator, the matching position to where it was on the subaru). i feel that the distance to the front of
the car is just too far for me to plumb with gas pipes(too much work and too much gas), so what i am considering is fitting this older evaporator i
have seen to the little bit of space that i have above the water tank beneath my rear bench seat. as a side thought, if i was able to run an air pipe
from the evaporatorup to the point behind the front seats where there was a vent on some bulkheads, then i could flow the air through the arm-rest
back into the main circulation, right? otherwise i will just run something hidden along the floor so that i can get some air up front.
does the evaporator need to be re-sealed for the new gas if it hasnt already? what sort of marking should i look for on it?
thanks for all of the help
Ryan
Brad
Threads: 332
| posted on April 21st, 2004 at 10:21 PM |
mmmm I wouldn't be putting the evaporator on your radiator it will need all the cool air it can get.
Just plumb the gas or it will not work well enough to bother doing. You need the evaporator in the bus or sealed to it very well.
Gas is worth bugger all so $$ shoudl only need to be spent on hose and connectors.
If you are going to do it you may as well do it right. Go and talk to an A/C guy he will set you straight and no doubt have some good ideas from
fitting them for many years
baybuscamperkid
Threads: 335
Mood: transported
| posted on April 22nd, 2004 at 06:44 PM |
ok thanks. just thought the condensor, being so damn big would be ok going behind the rad as this is where it is on the subi. i may be able to fit
it in the gap above the rad tho, as my new rad sits a bit lower then the last one sop there is a good bit of airflow above.
