| [ Total Views: 2210 | Total Replies: 18 | Thread Id: 216 ] |
pishtols
Threads: 10
posted on August 29th, 2002 at 02:13 PM |
help with rear disc for bug
hello...
just wondering if anybody can give me the run down of rear disc conversion for a beetle... (im doing a 74 L bug, and maybe a 68 1500) i have been
quoted for kits from places like Mr Bug in D'nong for like $800...... surely a set of discs and calipers are not worth that much......!! anything
else that i can match up..... maybe like a corrola??? i dont know, i guessing....
thanks
pishtols
Threads: 10
posted on August 29th, 2002 at 02:16 PM |
hello...
thanks
vw54
| posted on August 29th, 2002 at 08:10 PM |
go grab a coralla it might be cheaper.
555bug
WRX Bug Boy
Threads: 79
Theme: UltimaBB Vintage
Mood: turbo charged
| posted on August 29th, 2002 at 09:43 PM |
man 800 is not that bad. A sherman kit of (my opinion only)questionable quality is over 1k. If your handy you can make anything happen, George from
Custom Offroad up here sells a nice kit 11' ventilated, internat drum etc.. for that sort of $$ or you could just chase down some Porsche bits
that just bolt on. |
1303Steve
| posted on August 29th, 2002 at 10:05 PM |
EB Falcon rears can be made to fit, Jaks fitting some soon.
1302Steve
pishtols
Threads: 10
| posted on August 29th, 2002 at 11:24 PM |
eb falcon!!!! huh...... i got an EA falcon.... might just pull that apart...... thanks for the helps fellas... much faster with the replys than i
thought..... if u cant tell im new here, and im likeing it more and more.... :thumb
Buggy Boyz
Threads:
| posted on August 30th, 2002 at 07:46 AM |
Rear Disc
I agree with Steve $800 is not that bad. Most kits include new callipers, discs, pads, flex line and approval. Try doing it for less.
I just did one on Daz67's Manx. We used 2nd hand parts and had a lot of the other bits we needed already there. It ended up costing about $300
and took quite a few hours, ask Daz67 he ended up getting pretty pissed with it as it wasn't as easy as he thought.
I finished it off and I am sure Dazza would have if he had the time. What I am trying to say is that if you are pretty handy with a lathe and a
weleder you can make anything fit, but how much is your time worth and it is stopping power we are talking about, dont skimp on it and hit a wall.
A price idea for new parts:
Rear Discs - $140 pr
2nd Hand callipers - $70 pr
Calliper kit - $100 pr
Rear flex lines - $50 pr
Brake Shoes - $80
New fixed brake lines - twin flanges - $30
Type 3 hubs - $80
Mounting plates 2nd hand - $30 pr
Machine work on hubs - $50 pr
Total - $630
Does not include the time to do the mods and it takes a while. You need at least a die grinder to make it fit.
Now you can see that we are getting up to $800 and you still need to work it out and hope your ides stop you. Then you will need, in QLD at least to
get it tested by an authorizing officer to do a brake test so add another $100 at least.... Getting the idea ?
Don't get me wrong I have done a few now and am happy with them but I used a Custom Off Road designed and get it approved by the same engineer
who recognises the kit.
[Edited on 29-8-2002 by Buggy Boyz]
[Edited on 30-8-2002 by Buggy Boyz] |
daz67
A.k.a.: Darryl Hall
Qld Manx
Threads: 25
| posted on August 30th, 2002 at 08:02 AM |
Rear Disc's
As Brad said, If you are able to spend the hours and hours doing it, then make it yourself. But sit down first and add up the parts needed, then allow
for some minor stuff ups, then approx the time required, then consider it being legal!!!
My advice after going through the above, Contact George at Custom Off Road in Brisbane. His kits are very good and he uses Recond parts and I beleive
you can have it Blue plated at the end.
http://www.customoffroad.com.au
Buggy Boyz
Threads:
| posted on August 30th, 2002 at 08:06 AM |
Confimed
Yes George uses new parts and yes they get a blue plate once fitted. |
56astro
Threads: 74
| posted on August 30th, 2002 at 12:26 PM |
From what (little) I know about veedubs, unless you are going to race the bug you don't need discs on the back. You front wheels do 70% - 80% of
your braking. If you put discs on the back you may tend to skid your rear wheels.
I'm sure someone with more VW knowledge will reply though.
| Error |
35MPG on 101.3kPa
1303Steve
| posted on September 2nd, 2002 at 09:32 PM |
A properly balanced disc brake system will not lock up the rears, but if you want to stop dont use skinny tyres.
The beauty of having a motor in the rear is keeping weight on the rear tyres under braking, thats why ricers have tiny rear brakes.
I went from stock superbug rears to Type 3 rear drums, 914 Porsche with Golf calipers and now 944 Porsche with Boxster calipers and of course upgraded
my fronts, I had more rear lockup with my stockers.
56astro
Threads: 74
| posted on September 3rd, 2002 at 05:18 PM |
Got to agree there, balance is the key.
Std discs at front + rear discs = unbalanced.
35MPG on 101.3kPa
1303Steve
| posted on September 4th, 2002 at 12:05 AM |
You can get rear discs to work with stock fronts, you just need to pick the correct ones.
[Edited on 3-9-2002 by 1302Steve]
Che Castro
ankle straps
Threads: 79
Mood: (( }:-{D]
| posted on September 4th, 2002 at 07:58 PM |
drums have more stopping power than discs because they are self energising right? and thats why u usually use a servo on disc brake cars?
Jon
Buggy Boyz
Threads:
| posted on September 4th, 2002 at 08:28 PM |
posted by Che Castro
more stopping power ??? that don't sound right, they have more surface area contacting teh drums but less pressure I would think, yes with
leading shoes the pressure increase with roll. But I am sure some of the smarter people on here will offer a better idea.
If drume were better then why is everytjing disc ?? |
Kafer Lover
Threads: 71
Mood: Low
| posted on September 9th, 2002 at 11:12 PM |
So if you upgrade your front discs to something larger and leave the rear drums stock is this also unbalanced?
jakriz
Threads: 46
Mood: 2 headed
| posted on September 11th, 2002 at 07:39 PM |
bakes
I upgraded my front dicks form standard with the standard drums on the rear & the braking power is awesome, at the moment I can brake about 50m
later than the porsches at the end of Oran Park straight & after I finally get my Ford Falcon rear disks on it should be even more! Can't
wait.
regards
Jak |
Che Castro
ankle straps
Threads: 79
Mood: (( }:-{D]
| posted on September 11th, 2002 at 08:07 PM |
well i've never driven a disc braked bug but i thought discs required more pressure, the amount of pedal pressure to stop my car is quite minimal
considering it is unboosted.
the rotation of the wheel literally wedges the shoe into the drum, especially so because the shoes are of the floating design. Drums take little
pressure to lock up once they are engaged because of this.
disc brakes have a better feel because the response is more linear than drums due to their non self-energising design.
[Edited on 11-9-2002 by Che Castro]
Jon
daz67
A.k.a.: Darryl Hall
Qld Manx
Threads: 25
| posted on September 12th, 2002 at 07:30 AM |
Rear Disc
All I can say is,
My buggy started out with 4 wheel drums, then front discs, now 4 wheel discs, you can keep your drum brakes and I will see you when you extract your
car from the fence/wall/tailgate of other vehicle.
For anyone who thinks there drums are better, drive a car with discs, then comment.
Baja Wes
V6 Baja Pioneer
Threads: 94
Mood: Content
| posted on September 12th, 2002 at 12:29 PM |
Jon,
I know what your saying. Drums are self energising when set-up properly. Beetle drums only have 1 self energising shoe, whereas the dual wheel
cylinder kombi's had 2 self energising shoes.
The whole thing of drums being self energising in theory and discs requiring boosters doesn't seem to match up to reality very well.
I had 4 wheel drums, then I put discs on the front and the pedal pressure was lighter. The discs aren't self energising but must just be heaps
more efficient than the drum which helps to give a low pedal pressure even without a booster or the self energising effect.
And not all cars need brake boosters. I think a brake booster just allows car manufacturers to put small inefficient brakes on production cars and
still have an OK pedal pressure. Smaller brakes and a booster is cheaper than big brakes.
Look at the motorcycle industry. They aren't restricted by trying to make a cheap vehicle like the car industry. You don't see motorbikes
with brake boosters. Instead they just put huge efficient disc brakes on.
Ride an early 80's drum braked then a late 80's disc braked motorcross bike and you'll see the discs offer far more power, more feel,
and have a lighter application pressure.
daz67
A.k.a.: Darryl Hall
Qld Manx
Threads: 25
| posted on September 14th, 2002 at 06:30 PM |
Well Put Wes!
11CAB
If ya got it....Baja it
Threads: 321
Mood: Beach'n
| posted on September 14th, 2002 at 07:56 PM |
Drums versus Discs
Discs are able to remove heat better than drums and this is what brakes are about, converting kinetic energy to heat energy. But on the other hand,
look at 99% of Semi trailers still run drum brakes so they can't be that bad.
65 Meyers Manx
68 Country Buggy (KO 367)
68 Country Buggy (KO 669)
68 Country Buggy (KO 789)
68 Country Buggy (KO 815)
68 Baja Bug
76 Baja Kombi Twincab
56astro
Threads: 74
| posted on September 14th, 2002 at 09:55 PM |
A lot of semi trailer brakes catch on fire, though!
35MPG on 101.3kPa
