[ Total Views: 1060 | Total Replies: 38 | Thread Id: 22771 ]
Author: Subject: -- Lowered --Ride Height Problem! + Pics!
posted on May 11th, 2004 at 10:30 PM
The body can also sit on the pan cockeyed, a bit of work with a tape measure should tell you what out of wack.
Nice car, have you had any oil starvation problems with your rear wheelbearings?
1302Steve
MemberBrad
Threads: 332
Mood: Manx Buggy Building
posted on May 11th, 2004 at 10:52 PM
check your steering limiters are set even both sides as well
Brad
Meyers Manx Australia
Super Moderator65busser
Threads: 224
Mood: dakked
posted on May 11th, 2004 at 11:26 PM
It's the 'ol dilema. Do you want to drive it or look at it?
(As the Chief Choker once said)
That sure looks good though!!! How wide are your fronts and how does the offset compare to the stock offset?
Memberikube
Threads: 106
Mood: C h i l l
posted on May 11th, 2004 at 11:37 PM
how do i check steering limiters ? thnx!
MemberPHAT BUG
Dave says Bini's a fool
Threads: 192
Mood: Drippin
posted on May 12th, 2004 at 06:23 AM
You could run the new 145/65 continentals on the front,
they will be skinier & lower profile than yours, so should help a fair bit.
Memberkustomkool
A.k.a.: Damian Von
BEING KOOL AINT CHEAP
Mood: farked up...
posted on May 12th, 2004 at 09:40 AM
What Jim said change your ya tyres and it should only scrape and it should a little doing a full loced turn.Add dropped spindles and it will not scrape.I would go on the waiting list asap for a set of 135s.Or join the vwsleds and get a phat set of foxcrafts and a set of 125s.
posted on May 12th, 2004 at 11:18 PM
You dont have them on king & link pin front ends like on balljoint front ends, however the front bolts that hold your brake backing plates on are longer and contact the steering knuckle on full lock, limting travel, if these are mixed up you can get too much lock, also you can fit longer bolts than standard here to limit your lock, a bit of trial and error to get it right.
1302Steve
MemberVWFOOL
Threads: 572
Mood: inspired yet?
posted on May 12th, 2004 at 11:22 PM
don ur bug is now in the readers rides section, thanks for that...
One man's junk...
Memberikube
Threads: 106
Mood: C h i l l
posted on May 12th, 2004 at 11:27 PM
:D Thanks! :D
[Edited on 12-5-2004 by ikube]
MemberVWFOOL
Threads: 572
Mood: inspired yet?
posted on May 13th, 2004 at 12:24 AM
watever u do, just dont raise it up, its good the way it is
One man's junk...
